ishoppersmarketing
- May 23, 2012
the air leak
TS already responded that car in neutral (i.e. not moving) and rev engine still have sound. How can it be wheel bearing?
Oh, sorry never read properly.... my mistake
Battery alternator. Check whether your battery is charge up or not..
Aeroplane sound is often cause by bad wiring from ur headunit or sound system. The sound is from ur speakers. Especially when u r in neutral n u rev ur engine n the sound become louder. Quite confirm is ur sound wiring.
the sound quite long liao, almost 2 months, so i presume its not the alternator since it is still moving..
thank you all for kind advise. Will send to workshop to check all the belts first.
will update results for all to gain more insight if it happens to u(touch wood!)
ok, the problems lies with no oil/lubricant in the air con compressor.
mentioned that i send for regular servicing but no one ever told me about the oil.. the compressor totally no oil..
the mechanic says it is not the usual thing that servicing packages check.
so here it is... do take note of your air con compressor oil.
