Engine oil sinopec 5W40
elf108
Use won't spoil.
But also won't give u racing feel.
mp4005 help
Suspended
Still got people use 5w40?
Then use what ? Most now I think use 5w30 .. but as car ages , some switch to the thicker oil to protect the engine seals.
You can google more.
But higher end turbo cars use even thicker oils ..
Different engine oils are used for different purpose.
hachi
Simple engine use the common 5w40 no issue? Will spoil? Fuel comsumption? I used my shell 5w40 shell for many years even my engine can use 5w30.
zzzzzzz
newer "economy" engine uses 0w20, or 0w30 if 20w oil cannot be obtained
liquidh
The number in front doesn’t matter in Singspore when it is summer all year round.
Allblacks4442
Is just another EO blended in SG. Got it into my ride last month. $33.30 servicing.
ya, quite cheap for this EO. but finally i choose castrol:s21:. But will try this for next service. Maybe When reach 8k Then go to change EO. not dare till 10k
Allblacks4442
Different engine oils are used for different purpose.[/QUOTEmy car already 11 year, before this i using 10w40(semi). Now try this 5w40
