freespiritsy
- Aug 23, 2009
You know the conclusion already.
If you can predict your health's future, buy until age 65. Otherwise, buy beyond age 65.
You cannot be buying only one plan to cater to all you concerns.
It is impossible.
Split up your concerns (in dollar value) over the different stages/ages of your life, and check what insurance policies can cover those concerns.
Initial discussions should omit budget constraints, otherwise you hinder proper financial planning. Discuss and plan like there is absolutely no budget constraints.
Once you know exactly what coverages and how much of the benefits you need, input the budget constraints and purchase within affordability.
I will consider a policy beyond 65 yrs as nobody can play GOD as you've rightly pointed out. And as per your advice, I will make my decision based on objectives and having done that, I will then incorporate the $ portion to see if it makes sense based on affordability. tks Accesscode!
