Enough power?
kaikai1805
hi all,
my current specs:
gigabyte z77m-d3h with i5 3570k
gigabyte gtx670 2GB Windforce
120GB Sandisk Extreme SSD , Hitachi 1TB
Geil Black Dragon 2x4GB DDR3
Seasonic S12II 620W
just bought an additional Transcend SATA III 6Gb/s SSD370 Premium 512GB SSD. wonder if my psu is enough for my setup? thanks in advance
Elijahonli
hi all,
my current specs:
Seasonic S12II 620W
drives only take very low power... ur psu is able to power another drive without any issues.
mosmos
High Honorary Member
get a higher rating psu just in case you need to add more devices in the future, it will not case more~
MoneyFace =p
Each SSD at max 6W, each 7200 rpm HDD only around 10W. Tell me you need higher wattage just for these?? :s22:
Phen8210
620 watts is plenty.. no worries bro. Even 290x also no problem.
kaikai1805
am planning on going 4K monitor so looking at 980ti. doesn't seem enough power. another issue the space/room for the huge card and whether my board can support that.
Phen8210
no problem la 980ti.. uses less power :/, i also using the same case as u.. agsard xp right. i was able to fit a palit super jetstream triple fan in it.. no problems. just move the harddrives.
kaikai1805
I see, any idea whether my board can support? hmm plus pascal coming out in Q1 2016 leh.
