Computeron
- Mar 22, 2005
yeah now i am wondering if I should get a mix 2, or wait for CES to be done.
wait for ces.. see got wat new products... *check out doogee* scarli mix2s...
New update
Sent from Essential Products PH-1 using GAGT
Anyone know if the essential have any fast/dash charging?? Does any 3rd party charging brick and cable works??
Quick Charge 3.0. it's related charger works.
Sent from LG V30 Plus (V30+) #RaspberryRose ~ Red, Red, Red ~ using GAGT
Fyi, essential phone does not work on my aukey qc3.0 charger..Anyone know if the essential have any fast/dash charging?? Does any 3rd party charging brick and cable works??
Hmm, I'm using the type c port aukey ones.Fyi, essential phone does not work on my aukey qc3.0 charger..
Essential phone is not using QC 3 standard. Please do not buy QC charger for it. U need power delivery type chargers.
https://www.reddit.com/r/essential/comments/71hcn5/psa_our_phones_are_not_qualcomm_quick_charge/
https://support.essential.com/hc/en-us/articles/115015526928-What-kind-of-charger-does-the-Essential-Phone-use-
Ok thks bro..
Any idea how to stop phone idle battery drain? Taking up like 20% of overall charge...
Do you know which app is draining the battery?
Ok thks bro..
Not sure if you can totally stop idle battery drain. How's your overnight battery drain? I usually use that as a gauge if there is any battery drain issues. Mine drops 1-3% overnight which is similar to my previous phone.
The thing that draw most charge is screen and phone idle both about 15-20% each....
Which Android version is your Essential Phone running on?
Today I woke up with 100% charge still. I tried offing most of the social medias background data apps expect for WhatsApp wonder if that's the fix, but phone idle gotta check again today.
