enimen
- Aug 25, 2018
When you try to do it outside 'trained' service personnel to save money....
The battery was outside the car alreadyImagine you buy a Porsche but cheap out on maintenance at random workshop and have your car burnt into a crisp...
Is the car a total write off?
Workshop confirm roti prata gao gao.Is the car a total write off?
Workshop have to compensate owner new car?
Just replace the battery will do, the battery is under the car if you noticed in the image. Think the workshop wasn't able to handle the battery system properly causing a short.Is the car a total write off?
Dude.. you know how many EVs china has? i called so many Didi, I have only once set in an ICE Didi. And I average call about 4 Didi a day, sometimes 6-8.Is this true that some parts of China, EVs are not allowed to park in basement car parks?
Don't tell you.How many EVs are there in china?
Don't tell you.
Boss, sometimes this kind of thing - the car up top "seems fine" - but:Just replace the battery will do, the battery is under the car if you noticed in the image. Think the workshop wasn't able to handle the battery system properly causing a short.
The car just needs a new battery, compliments of the workshop.
Yo... I meant the battery is already removed, it's sitting on elevated position below the car. The battery is not in the car's below.Boss, sometimes this kind of thing - the car up top "seems fine" - but:
- Existing wire harness have its insulating sheath, half-melted off. Copper strands may be intact, but it's no longer weather proof.
- Electrical fuses melted or compromised - fuse box same thing also
The car may start, but few months down the road some electrical gremlin is very likely to be kicked up. Check engine light, module warnings, all the nonsense.
I wouldn't waste time trying to fix or replace the harness or fuse boxes - these things can easily be 5-6 digits, especially on a Porsche.
Yeah, I know.Yo... I meant the battery is already removed, it's sitting on elevated position below the car. The battery is not in the car's below.
If the battery burned with the car, it's a total loss already after 15mins. Batteries burn hotter, faster than petrol. Don't even think can salvage, scrap metal is better.
Very likely, the harness and wiring comes with it. I think it's dumb to reuse harness or wiring for battery related components.Yeah, I know.
By the books, I think "replace battery can already".
But for me, I see like this, I know the wiring also half-gone even though it's up top. I would not accept just a battery replacement from insurer - and will insist to have the wire harness and all electronic (plastic) modules replaced as well.
