Extend desktop using VGA splitter?
Maeda_Toshiie
With a C2D integrated graphics, is it possible to have two monitors that display an extended desktop?
If yes, which shop sells a VGA splitter?
cnt
if u mean both monitors showing same thing den yes :s42:
royfrosty
Yes you can. My office dual screen showing 2 different things can be done.
BUT is on i5 1st gen. So not sure about your C2D.
But whats your purpose?
cnt
I tink older mobo can use 1 digital + 1 analog. eg vga + dvi :s42:
Maeda_Toshiie
Basically I have a C2D system where I want to hook a second monitor up with, so that I have two screens to use at the same time. I just want to make sure that I buy a splitter that can do what I intend.
cnt
which mobo u using? got use gfx card? :s42:
cnt
den u check if there is a vga + dvi output :s42:
game goondu
It's a Dell in the office. No discrete card.
office dell pc should be integrated gfx.
so there is only 1 VGA port.
if you buy splitter, you see the same thing on 2 monitor.
i research before, what u need is those usb to vga adaptor...
1 end connect to your office dell usb port. the other end connect to the 2nd monitor.
take note of the supported resolution of the adaptor when u buy...
dewjef
Before I change to PC recently, I was using this USB VGA with laptop for 3 monitors setup.
http://www.amazon.com/gp/aw/d/B0038P1TP4/ref=pd_aw_sbs_3?pi=SL500_SS115
