External drive with a USB-C connection?
Lophophora
Hi,
Apologies, this is a total noob question but I don't know who to ask. I want to purchase an external drive and connect it to a computer or a video switcher that both have a USB-C socket. But all the drives I see in the shops have a USB-A cable... Will it work if I simply use a USB-C cable instead, or do I need to purchase a specific drive for that?
jtjt00
Look for Samsung T5/T7 SSD, all are using USB-C port.
Lophophora
Thanks but I need a 5TB disk and SSD would be way too expensive.
For some reason I can't find an online store that mentions if the drive comes with a USB-A or USB-C cable. Even on the official Seagate website they don't mention it.
NightRaven49
if like this ah, suggest u get a hard drive dock and source the 5tb disk separately. orico docks use standard usb interfaces like micro usb and type c, so can just get cables with type c on one end for ur com and the correct plug on the other for the dock.
yusoffb01
5TB external use smr. it is dam slow. having usb c or micro usb is irrelevant. 8TB wd external is faster.
hg2
Go lazada toshiba official shops, they have the large capacity USB-C portable hdd.
or just get a $0.50 USB C adaptor from shopee... works for all my toshiba portable HDD, samsung SSD, phones, Macs.
kandinsky
... or a video switcher that both have a USB-C socket.
Something like the ATEM Mini Pro/Extreme/ISO? I'd check the specs and user reviews first, the tried and tested one seems to be the Samsung T5. T7, quite a number reported compatibility issues. Much less HDD, may not even work. If referring to another switcher that supports HDD, please ignore this post :D
luei74
Please Check WD 2.5" 4TB My Passport Ultra. Did received 2x for recovery with USB Type C.
Instagram
I got an internal HDD which i now place inside a case with usb C connection. The case i buy less than $10 on shopee
