External Sound Card
tanwbb
Sorry for this nerd question. I have a mini PC that does not come with any sound card. So my question is can I just get an external sound card as a workaround, like I read on Internet, or I have mis-understood the product?
gregory_choo
you can get usb soundcard.
if you want best sound, just for playback only, get usb DAC
cheapest way is usb audio dongle, less than $5 :)
e.g https://www.aliexpress.com/item/33056020608.html
saif07
how mini is your mini-pc? Are you referring to the audio jack not working? Simplest workaround should be USB sound adapter like creative sound blaster or cheaper ones from ugreen. It should work as long as you have an available USB 2.0/3.0 port
naked123
i just use apple type c to 3.5mm adapter
if pc no type c just buy adapter
sound quality wins most at this price point
xhlee87
What kind of mini pc? Most consumer mb come with integrated sound.
Having a sound card to have basic audio is 20 years ago technology.
Hafi
Mini PC usually HDMI output/s... mine have dual HDMI outputs that can hookup to dual monitors /w sound.
86technie
Alternative is consider getting a BT speaker.
Example Logitech Z337 BT just connect to BT no need wire.
overcrash
get a usb dac and a portable one at that.
you can use it for your mini pc, or for anything else, even your laptop or mobile phone :)
