facial wash recommendation?
SunitaRao
Salicylic Acid acid good for men facial also?
I using this now.
Salicylic acid is good for men too! Been using The Ordinary products. Honestly overrated but definitely helped my skin. Forced my husband to try also, his pimples and bumpiness is reducing! But check with your dermatologist also.
sbv7230
Using Lab series (Multi Action Face Wash)for yrs...
Will not dry out your skin but still feel clean and smooth..
Whitecamel
Face feels really clean after using this.
No need to buy a separate facial scrub as this works as one as well.
I think for facial wash, it depends on your skin type. For oily/combi skin, Cerave Renewing SA cleanser works wonders! I think for dry skin, can try out Simple Micellar Gel wash. Hope this helps! :)
kookiecorgi
any reco on facial wash, moisturiser and toner for dry-normal skin?
Looking to get my skin to shine like an oppa.:s13:
schipperde
laneige
i'm using laneige multi deep-clean cleanser.. face feels clean after washing. no dry feeling either
kyliah31
been using the clean and clear essentials face wash for a while now. sometimes i change it up with the st ives blackhead clearing scrub which smells great :)
SunitaRao
a lot of people i know use cetaphil, great for sensitive skin
Cetaphil is good for both dry and oily skin as they have a large range! I just started using Cerave, very hard to get in SG but you can find it in Shopee. Gives your face an extra radiant glow and glass skin (if that's what you want to achieve) and it also reduces face pigmentation!
chuaseng365
I have dry skin and I've been using the Paula's Choice Pore Normalising Cleanser and their Skin Recovery Replenishing Moisturizer and it really helps with hydration! Their skin recovery line is great and helps to get that glow. Got a really good deal with shop vouchers on Shopee
hereiam7788
dun find it nice to use, luckily i only bought the trial pack. still prefer more decent brand like kiehl's etc.
eyz
I'm loving this.
wash very clean, and the scent is very soothing.
any recommendation from iherb?
Tea tree oil wash
I just randomly bought it, when I was looking for some natural cleanser. also, it's one of the top ranking cleanser.
it's cleans rather well, but then again, I think Atorrege AD+ Face Wash foam cleans so much better.
not sure whether it is due to the foam being more molecularly, that's why it's able to clean so much better.
same goes for those foam hand soap, it just clean better.
