Fan Controller
deepblue_82
any good ones.. ?
any mid range ones?
seems not much ppl using fcs...
Teng Zai
FC's add a lot to the looks but not sure if i want to build my rig with them. Seems like lot of cabling..
tony_ong
saw some on dx.com but didnt get them cox normally i jus on the desktop to play only. after that off liao so just let them run at full speed
JasK
Does anyone knows which fan controller is full sized like a dvdrw?
royfrosty
Have. I remembered looking at amazon. And im looking for 1 locally. I was thinking to use that. Cause currently im contemplating whether should i get a splitter to connect it to the mobo plus the psu and supply it all to the case fan?? Then from there control the speed via bios.
technoglitz87
Using a bitfenix recon, would say it's really nice on aesthetics. Build wise i still prefer my old scythe kazemaster. Chamoxa might still have em lying arnd.
recon can find almost in most of the shops, got mine in cybermind, white edition
JasK
I don't think a full sized fan controller exist in the market?
t258jgn
BitFenix Recon 5.25" LCD 5 Channel Fan and Temperature Controller
or
NZXT Sentry 2 5.25" Touch Screen Fan Controller
JasK
or
Jerome, dont mean it is 5.25 in size, i meant the length of it, exactly like the size of a dvdrw, not the front of it.
limster
I bought 3 pieces from China ebay seller a lookalike model. All 3 still working after a year.... much cheaper.
deepblue_82
or
i am also thinking of the nzxt.. isit good?
but after looking at BitFenix Recon it seems not bad too.. dont see it.. how much isit?
JasK
I have spare NZXT Sentry LXE External Touch Screen Fan Controller, brand new in box, anyone keen? dont need it liao, cuz impluse buy
