Fan Controller
enenyi
Go BIOS configure fan speed? Fan controller is for the lazy/convenient or the itchy fingers. :)
deepblue_82
like i can lower to 20-30% when i am watching dramas..
then turn back up when i am gaming.
please i really need help on this.
ckjoe234
I recommend the bitfinex hydro pro...6x 30w per channel n allows u to control ur leds on the fans too....
devilwahaha
Are you using the Asrock b75 board? If so you should have the Asrock Xtreme Tuner Utility when you installed your mobo drivers, just open that program and under fan control you can control your fans connected to your motherboard.
Note it only works for fans with PWM, meaning they have 4 pins connector.
deepblue_82
isit easy to install a fc? anyone can help? i wan to control my gfx fan.. front back fan...
shadow84
Get some fan splitters. Like 1x 3 pin to 2/3/4 3-pins splitter. Den connect to fc and fans. Connect the splitter to 1 channel.
Ur gfx fan is at what position?
Godeau
Easy. Just buy the cheapest one to play lor, even 10W per channel fc also can since most consumer grade 120mm fans roughly only take 1~2W at 100%
Edit: the gfx fan, u mean side panel fan or the fan on the gfx? gfx fan, to control it, you can download software like msi afterburner
muddle
U just plug the fan 3 pins to the fan controller. Then connect power to the controller. Thats all.
Btw i am using nzxt sentry mix 2.
