Coool11
- Jan 20, 2015
Dear All,
I will be using NZXT S340E casing which has 4 fans slot. The front 2 will probably be taken by AIO (X62 Kraken) which leave the top and rear available. Should i be using a fan hub (NZXT grid) to control the fan or should i be plug it directly into MB. The MB i will be using is MSI Z370 Gaming Pro Carbon which has four 4 pin sys fan. What are the pro and con of using fan hub, better cable management and aesthetic?
And also, the casing comes with 2 FN V2 Fans (1200rpm). I have a few Gentle typhoon AP-15 1850rpm fans. Is it better to replace the casing fans with the GTs?
