Fibre Optic Cable (For Broadband) = Same As Toslink Optic Cable ?
so is the Fibre Optic Cable (For Broadband) = Same As Toslink Optic Cable ?
i don't dare to disconnect the fibre optic cable (very thin yellow cable) from the modem since it looks like it'll break since it's so filmsy !
if it breaks, can use a Toslink optical cable or need to buy back the exact same yellow colour cable ?
86technie
Different, if you want to replace the cable.
You can get the cable from Challenger, the cable for ONT is Fiber link cable for data.
Toslink is for audio and both these cables the connecting heads are different.
roger.............many thanks.............
so the fibre cables all so super thin and filmsy ?.............like will break easily leh...............and so very long some more...........
86technie
True it will break so try not to bend or curl it too much as once break the entire cable cannot be used.
86technie
Errr... it's standard no custom type just have to be careful not to bend or curl too much.
