FiiO X5 Teaser
Nakedtoes
aren't they beauty?
faster faster give review
weng
x5 is more neutral and musical. typical TI sig i guess. nothing like the x3. i would take x5 over dx50 any day too. and considering the demo unit i tried was still new.
doki81
apparently..the reviewer unit that i hold has a different circuit than the normal retailing unit..
now i am curious..shd i go demo the E1 unit or E1 unit also same as reviewer unit..
update: just got news from Joe@ Fiio and the review unit even though have different circuit but the SQ wise is the same as the retail unit :)
weng
so what's the diff between the 2 circuits? :D
FatalethaL
the X5 is indeed more musical, however it sounded more like a single DAC than a dual DAC.
Also, the micro detail retrieving isnt as good as DX50 (v1.2.2).
but in terms of ease of use and UI... X5 has a slight upper hand over DX50 imho lah
doki81
review unit no lag , let people play until song, but retail unit..... :eek::eek::eek: press button whole thing freeze
it might need a factory reset? mine initially have some lag...but then after factory reset..everything went smooth..
zhubajie
did u all fill the onboard memory (or did they disable this function) or at least fill it up to 80% capacity and see if the UI is as smooth ?
or use external memory storage at full capacity...
doki81
onboard memory? u mean internal storage? x5 dont have internal storage...
but if you talking about the ram......i dont know how to check ram usage..
weng
Wa single or dual dac you also can differentiate ah. Power! :D
zhubajie
ya i mean internal storage..
they disable it for the review unit in case pirated copies of music files is found in the unit and they dont wan to be blamed for distribution....... or actual retail unit also dont have ?:eek::eek:
doki81
I don't think retail unit will have internal storage also le. they never mentioned internal storage...
FatalethaL
basing on what i have heard on HM901, DX100, and AK120.
dual DAC normally have better cleaner, lower floor noise, wider and deeper staging (the feel of not having a wall to determine the size of the stage, but rather, it feels like an invisible wall), imaging is more precise.
but this X5 is different leh... so it doesnt really sound like a dual DAC compared to 3 listed above.
maybe it is the characteristics of different types of DAC. but... will it make that much of a difference?
weng
Not sure if that would be a fair conclusion as they are all of different makes in the first place. How much is attributed to that extra dac, how much is attributed to better implementation, also duno, unless there is a particular model, one version with single dac, one version with dual and everything else the same.
And btw, dx100 is dual dac? :D
zhubajie
yeap, unless all the DAP using the same dac and implementation, either single or duo
i dont think its fair to conclude like that also
same dac, but different brands might have different implementation also
Nakedtoes
one very good exampe x3 vs dx50... same DAC but totally different sound from HO i guess the amp differentiate the sound by a lot
