agree that the allocation is better that what my friends purchased.
but i did a quick calculation. after 4 years, you are down 175%. after 10 years, you are down 165%. you need another 33 years to get back the 165%. i know my estimation is based on 0% appreciation in prices and is not very fair based on what agents project.
Actually this way of estimating is more correct than what most agents do.
It is why I advocate the use of the ad-hoc top-ups in the early years so that you can take advantage of any gains your funds might make in the early years in order to break even much sooner than you initially thought.
For example:
In your first year you invest a regular premium of about $1,400 (usually the lowest it can go). You get 20% of this back in your first year, amounting to $280. Repeating this calculation up to the 4th year (where you start getting 100%), the total amount you are down is:
80% (1st year) = $1120
50% (2nd year) = $700
45% (3rd year) = $630
Total returns required to match in $ terms = $2450
Assuming you ad-hoc top up about $2000 in your first year, your total investment amount for the first year = $2280
You therefore need a return of about 7.5% in your first year (from the funds chosen) in order to cover the amount that you are down from the first three years.
However, you still haven't broken-even!
You must then calculate (and its a lot easier once the agent shows you the B.I. and you factor in the ad-hoc stuff) how much you would need (in terms of returns per annum) in order to break even. This usually occurs around the 12th year (with no ad-hoc) with ad-hoc the cash value accumulates faster so it's usually a good deal sooner than the 12 years (especially considering that fund returns can be higher than 10% p.a. and the B.I.s are all calculated at 8% projected).
Of course, the higher returns will go to those who do their homework on the funds, just like with any other investment product.
