Hello techies, I'm intending to build my first PC and I need some advice regarding the parts, overall compatibility and budget.
I'm a medium-core (lol) gamer; I wanna get games like Farcry4, Witcher3, E
, WoW, etc. I'm fine with playing them at mid quality.
I also do quite some programming and debugging. No intentions of running servers or VMs at the moment though.
Here is a basic breakdown of the PC parts that I intent to get:
CPU: i5-4690
MOBO: Gigabyte 1150 H81M-S2PV
RAM: 2x 4GB RAM 1866Mhz HyperX
GPU: MSI GTX960 2GB
PSU: CM V550 Power Supply
HDD: WD Black 1TB
OS: Wins8/10
Monitor: ? (What is a affordable monitor to game?)
Wireless adapter: ? (Do I need it since it's a desktop? I can just run on wires, no?)
CASE: Cosair 200R (will it be able to fit my parts? I don't know how to tell)
My budget is $1200. I've checked most of the price lists from SLS but this build is at least $1500 assuming I get a $200 LED monitor. According to my needs, am I able over spending on parts which I will not fully utilise? I went to PCpartpicker to check on compatibility but I do not understand whether is it compatible cause it showed some notes at the bottom. Am I able to build this rig under $1200?
Also, do I need to get the wires to do my own wiring or will I get them as I buy the parts? Sorry to sound so confused here because it's my first time and I don't want to overspend for things that I will not use.
CPU: i5-4690
GPU: MSI GTX960 2GB
HDD: WD Black 1TB
OS: Wins8/10
