For advice on pre-built customised PC!
castper_135
Hi tech gurus,
Pls advice me if the following Dreamcore bundle is worth the price?
AMD Configuration:
– AMD Ryzen 5 3600
– ASUS Prime B550M-A Wi-Fi
– AMD Stock CPU Air Cooler
– 16GB (2x8GB) Patriot DDR4-3600MHz
– ASUS TUF3 RX5600XT
– 512GB Patriot VPN100 NVME M.2 SSD (R:3300 W:2200)
– Optional HDD Upgrades Available
– 4 x 120mm Addressable RGB (ARGB) Fans
– Wi-Fi 6 + Bluetooth 5.1 Included
– 650W 80 Plus Rated PSU
– Dreamcore Ghost V3.0 Chassis
– SuperSolid T24 FHD 75Hz IPS monitor included
Current pricing: $1274 without any add-ons/upgrades
Do let me know! Thanks :)
GotBetrayed
Hold on for next month. When rtx 3060 ti launch just topup abit get better rig better. That monitor 75hz. Not worth.
yusoffb01
this one is advertising for dreamcore. got a few threads asking for opinions about dream core
tsteo77
Hi tech gurus,
AMD Configuration:
– AMD Ryzen 5 3600
Worth it if got on site warranty.
minuteez
I think the specs you mention is on sale for 999 today. :s13:
You prolly will need to get a third party air cooler since the 3600 runs quite hot and the DC only giving stock AMD cooler. Can prolly just get the air cooler form them but I not sure if it will affect pricing & delivery date.
Alternatively, can install your own. Do check if it voids warranty
FroztSpectre
Hi tech gurus,
AMD Configuration:
– AMD Ryzen 5 3600
TBH, quite a good deal if you looking for an immediate upgrade.
For comparison, here's my build that i recently put together (amazon and lazada).
Would be around the same price if i drop my CPU Cooler. But then no Monitor, and no WiFi.
The $999 version is for Intel bundle, and using GTX 1660 Super.
Intel Core i5-10400F / MSI H410M Pro / MSI GTX 1660 Super Ventus XS OC 6GB
AMD Bundle shows as $1,249.00 for me.
castper_135
Hey @FroztSpectre,
Thanks for the comparison! Do you think i should find 1 mobo with display port or just use the HDMI-DP adapter instead? Currently, i'm using the benq zowie xl2411p
