Four Galaxy Note 4 Accessories
Noirkw
Bro can pm where to buy?
Lobaba
feels like note 3 was based on sgs2...note 4 based on sgs3/4. I like note 3 design more than note 4 =/ but it's time to let it go let it go~
kero89
Folks, I checked-up a few more shops and can confirm that currently there is NO ‘tempered glass screen protector’ in the market that is actually customised for the Note 4.
All the brands (premium or cheapo china make or lobang) create a 2-3 mm gap in the borders of the screen. Apparently this is because of the unique surface features of the note 4 screen.
Not sure if it is a manufacturing/design fault (screen gate?) but the glass screen appears to suddenly taper off/curve down by 0.5 mm or less, all round the 4 sides before the tiny gap that joins the metal frame.
The air bubbles elsewhere, are more to do with the quality of the screen protector.
Erm, its 2.5D screen, found on S3 and Note 2 previously, currently iPhone 6/+ are also onto this 2.5D screen that curves down at the sides. :D
Either you go for shield which should be able to cover 95%, or go for glass/PET sp that will leave around a 3-4mm gap to the corner.
pm
Folks, I checked-up a few more shops and can confirm that currently there is NO ‘tempered glass screen protector’ in the market that is actually customised for the Note 4. I am talking about all the items (various brands) that are labelled as ‘for SAM Note4, 0.26 mm).
All the brands (premium or cheapo china-make or lobang) create a very noticeable 2-3 mm gap in the borders of the screen. Apparently this is because of the unique surface features of the note 4 screen. Over time, I guess the exposed adhesive underneath will attract a lot of dust and small particles. Regretfully, I was told that even a glass or PET screen protector will leave a 3-4mm gap at all the sides, all over the screen!
Vincent87
Hi does anyone know where to find note 4 verus iron shield? Please pm me thank u so much..
Deavenger
Make a trip to burlington square to see the accessories.
P2o mobile right?
Thanks adix kor kor. ..but your shop was so packed yestedayat and their spigen case quite good quality
