FPS and PSU sleeve cable
ProGamer84
Hi, i will like to check, How come my FPS keep on Dropping from 130 after a few about 10mins the fps drop till sometime about 50+ to 70+?? My dota 2 setting all in Ultra High...
And also Regarding on PSU sleeve, how much is the market are selling it???
Encrypted11
Premade ones like silverstone cheaper.
Customised ones from mainframe (lutro0), cablemod, mdpc, moddiy, ppc, local made ones etc will cost far more. There's no real market rate. Sleeving type, flexibility, cable "heft"/thickness varies.
My Lutro0 customs set costed $130+ (EPS+24Pin+6 &6+2GPU). You can't draw direct comparisons.
Elijahonli
130 fps in dota 2? definitely something wrong.
Custom sleeved cables for psu are typically around 150 give and take..... extensions are much cheaper, but your case needs to have ample room to hide the extra length of cables at the back if you want them to look nice from the outside
ZrE0_Cha0s
whats your pc specs?
and as for psu sleeves u might need to check which psu using and look for it at taobao, unless ur psu is those generic, den maybe can buy similar product that have and just plug in to use.(though its will be better to use the correct port for it.)
ProGamer84
ok... cos i got a custom sleeve saw on HWZ ppl offering about $70 bucks..
what thing go wrong?
My spec is i5-4690k, 16gb ram, mobo asus maximus ranger VII...
LiLAsN
Based on your PC specs shown on the right, if that is correct, then it could be a case of bad Casing and to an extent, ventilation. Did you have this issue before with your older case prior to the Corsair 570x?
If this issue is a new one with your current casing coupled with your GTX 1080, I can recommend 5 solutions.
1) The most sensible solution, get a better case fan. Do not depend on the stock case fans since the all-glass case of yours seem to be trapping heat. You need a more powerful fan to help move more air through your case. But this will cause a lot more noise though. So do take note.
2) Lan lan suck thumb. You have to buy a new case. Yup. Quite a sad option but welcome to Singapore.. Where our hot and humid climate may result in our electronics to perform worst than that of our western counterparts where you may have seen the reviews from. A metallic case seem to perform better because metal helps to dispel heat evenly. That is why our heatsinks are all metallic. Glass, well... I myself notice that my new case with Tempered Glass seem to give off a strong heat from the glass itself. But my second case that has a darker tempered glass seem to keep the heat away from my face better.
3) Another option too is to get Aircon. So it cools down the overall temperature in your case. And most importantly, your GPU from heating up too much and throttling as a result.
4) This is an option that I myself will be adopting soon for my next GPU. I am getting a GPU with an AIO cooler already installed. It will give around 15 degrees or more improvement to an air-cooled GPU as seen from comparison results. Just like how my CPU performs cooler under AIO cooled as opposed to stock cooling.
5) Water cool your whole system. Not something that I would do myself since it is a bit of an inconvenience for upgrades of PC parts like the GPU. Cost of watercooling system starts around $300+.
lalalalalala
60 fps more than enough for dota 2. Don't even know if theres a difference above 60.
Anyway it should either be the client buggy or your driver buggy or ur monitor
Can't support
Sent from OnePlus A0001 using GAGT
ProGamer84
i dont think is my case problem.. Cos inside got total 6 fan. And i touch the TG not very hot also.. just warm.. my GPU tem at 43C
Can't support
i using a normal Full hd monitor acer was a old want...
Elijahonli
you can try reinstalling dota 2 and see if it helps...
You mention that after 10 mins, it drops to 50-70, does it stay at that range or occasionally only?
ProGamer84
normally what is the higher fps when using ultra setting? on gtx 1080 gpu...
Elijahonli
i dont have a gtx 1080 to test, but on my gtx 1070 should be avg around 140.
during intense fights maybe droping to 100-110?
i can do further testing tmr as most of the time i run the game with vsync on to save abit of gpu power...
make sure u are not running the game in dx11/openGl/Vulkan mode as those modes currently have bugs with 7.0 update
ProGamer84
I checked with my frd also.. When is fightign the fps will drop. But gtx 1080 should get much more higher FPS right? On the lobby my fps will get ard 128 to 130..
i not sure my game run in dx11 or not. i just simple down from steam and then just play like that. other setting i didnt do at all.
royfrosty
If you mentioned that your card heats up till 43degC then there is definitely something that doesnt stress the card at all.
Check V-Sync option, check other things that Geforce Experience have set for you.
I think you have to check your options and see how it goes from there.
Btw, it does not mean that you put more fans = better cooling. It depends on how the case is being structured and how are the fans being placed and how much air can the fan brings in.
ProGamer84
Just turn on my pc, and when to go dota. the Tem was at 42c and fps at 128. sometime will drop to 110+. But when i engaged with war, then the FPS will Drop to ard 60 onwards. I check with the case ard with ppl. so far they dont have this problem.. I was wondering my FPS problem weather cause by my monitor or not? so far my games all had optimize it...
Not sure what drivers you're using.
But early anniversary drivers (WDDM2.1 - 368.9x? to 370.xx) had a fair bit of performance issues, especially on OpenGL. But other random titles like csgo were also affected back then. If you're on any of these (while unlikely) you can try another version.
https://twitter.com/johnwinkmsft/status/783392562690138113
my GPU and my geforce all using new drivers...
shadow84
Is your gpu fans spinning? Did you remove the sticker?
ProGamer84
Damn the cable sleeve so expensive like ****. Just a extension cable only cost $70 wtf.. and just 1 to gpu 1 to mobo.. kns...
