Frequent blackscreens NEED HELP
woon6138
Hi, i just build my first gaming pc and i'm having some trouble with it... every now and then when i play games like CS:GO or Dota 2, my pc will randomly go black screen and the fan will start spinning full speed. Can't even get the screen to on let alone stop the fan spinning unless i restart the whole computer... Keyboards and mouse are still working when the blackout happens... Need Advice on what to do. Thanks.
undead102
Could be gpu overheating. Check if the fan speed suddenly went full speed is your gpu fan or your cpu fan. If gpu fan maybe could be overheating when your run your games. Could also be that your gpu faulty.
Monitor your gpu, cpu temperature with hwmonitor and check see if overheating is an issue.
Fan spin full speed is either faulty gpu or overheating basically. Or you probably go and set your gpu fan speed to maximum with msi afterburner etc.
yusoffb01
Don't tell me you bought gpu from an Indian shop.
They like to sell faulty/returned stuff
ZrE0_Cha0s
maybe if u can. reassemble your pc. make sure everything is plug in proper and make sure it doesnt wobble and loose. do a triple check on everything. den boot up again and see.
woon6138
Hi, im currently using a ASUS GTX1060 STRIX edition, can i use MSI afterburner with it? sorry new to computer building!
woon6138
no component inside is loose and wobbling though :/
woon6138
maybe u can list out every parts u are using?
Intel Core i5-6500 CPU @ 3.20GHz
Asus H170 Pro Gaming
ASUS GeForce GTX 1060 6GB ROG STRIX OC Edition
Corsair Vengeance LPX DDR4 8GB 2133Mhz
Samsung 850 EVO 250GB
Corsair CX650M
Windows 10 Pro
ZrE0_Cha0s
Corsair CX650M
Windows 10 Pro
have u tried your onboard gpu to test it? (by removing your discrete gpu
woon6138
Hi, i found out that it is the GPU fan that runs full speed when the blackout begins... is it because my system draws too much power that my psu cant keep up thus cannot keep up?
ZrE0_Cha0s
hmm...that means your gpu might be a lemon in 1st place. and beside that gtx 1060 dun need so much of juice. if it takes too much probably its over its tdp and it will stop running.
anyway u can try to see the power reading from bios or download hwinfo to find out.
undead102
Could be that your GPU thermal paste dry up thus causing the GPU chip to overheat that is why the fan speed spin at full speed tp try to cool it down.
Try monitor your GPU idle temp and load temp check if it's normal. If not GPU can do exchange or RMA le.
Cannot be 3rd party software as I think you never install any MSI afterburner or other 3rd party software and try to be smart and set fan speed to max right? So don't think this the cause.
Try use hwmonitor check the GPU idle and load temp.
Normally GPU fan speed will never go to full speed in default. Even if playing game at load temp fan speed rpm will be increase slightly only if you did not try and modify the fan speed curve.
woon6138
Hi, thanks for the help. I took out the gpu and install it at the other pci-e slot and it worked perfectly fine. Thanks!
ZrE0_Cha0s
hmm...so weird. u mean the 1st pci-e x16 doesn't work well and the 2nd pci-e slots work perfectly fine. and i thought that GTX 1060 needs a minimum of x8 to work? (well in nvidia SLI but not sure if it applies to single gpu.)
next if this is so. maybe either the slots issues or your cpu issues (though i cant find any good reasons to come out with.)
woon6138
yea i went whole day wifout a single crash or blackout when i did the change, perhaps something is wrong with the motherboard ;/?
ZrE0_Cha0s
maybe if u can, find who is the distro (if u remember the stickers on the box), go call them up if u can bring your whole pc down for them to diagnose. and let them check if is it the mobo issues or not.
