FSMOne web platform
Converged
After much consideration, i hv decided to switch my IWDA (SCB) to VT (FSMOne RSP). I'm fully aware of the witholding tax and estate tax issue with US ETF, but the cost saving is quite significant.
As I am investing S$800/mth for IWDA/VT, this is my comparison.
1) SCB forex spread = 0.4%, FSMOne forex spread = 0.25%
2) SCB brokerage fees = $10.7 * 4 (batch 3 mths), FSM brokerage fees = $1.07 * 12
3) IWDA witholding tax = 15%, VT witholding tax = 30%. Assuming dividend at 2% pa, the saving from IWDA is 0.3%. (corrected)
4) IWDA TER = 0.2%, VT TER = 0.09%
5) FSMOne has dividend handling fees of $2.5 per dividend. So its $10 per year of dividend loss.
Based on the above number, I use the spreadsheet created by another forummer, VT annual fees is S$43 (include dividend handling fees) vs IWDA S$96 (didn't include opportunity cost).
However, this comparison only applicable to my case.
Can i create FSMOne just to convert sgd to usd then transfer the usd back to SCB for purchasing of stocks? Are there any hidden fees other than the fx spread?
GhostZM
The fx rate on FSMOne isn't worth it.
You may consider to use Transferwise instead..I believe the fx rate is better and fees are lower.
CheerS!!!;)
Converged
CheerS!!!
Have u tried transferring usd from transferwise to scb usd trading acc before? Heard the wire fees from the bank is quite significant
https://transferwise.com/us/blog/fees-changing-usd-jan-18-sgd
Posted from PCWX using Nokia 3310
GhostZM
I dun have a SCB USD trading account. I just transfer it back to my DBS USD account. The fee is just US$1.40.
CheerS!!!;)
wutawa
GhostZM
Transferwise charges 0.44% for sgd to usd? Isnt it higher than fsm?
https://transferwise.com/sg/multi-currency-account/#pricing
Dbs fx spread is 0.7%?
https://www.dbs.com.sg/personal/rates-online/foreign-currency-foreign-exchange.page
Not sure about the transfer fees though
Even after taking into account the conversion fee , the FX rate on TW is still better than what FSM is offering..
I came to this conclusion after trying out the conversion on both platforms. But if you have doubts, just stick to FSM ;)
CheerS!!!;)
klanddt
CheerS!!!;)
Can I just confirm that your DBS USD account did not charge the 1/8% commission? Thanks.
5408854088
there is a minimum 2.50 USD as dividend handling fee for US stocks. what happens if the dividend is less than 2.50 USD? will the minimum still apply or will they just take whatever that comes in?
makav31i
If it is less than US$2.50, they will deduct whatever that was issued... That's what happened to my RSP on VT which issued dividends last month or 2 months back...
5408854088
thanks! hope they can enable LSE trading in due time too.
makav31i
If they added LSE and introduce some of the ETF for RSP, FSM will be the go to broker for most Singaporean investors so you don't have to open so many different broker accounts to handle different kind of transactions...
5408854088
spvnnn
Is FSMOne down for everyone? Why do I see a maintenance msg on the site but it's stated that they're doing scheduled maintenance on Sat, 9 May. A bit worried because my RSP money got deducted on the 8th but I did not see an increase in my invesment holdings on that day. Was going to see if it gets updated today but then now it's down during trading hours???
EDIT: message on their website was edited to remove the date of maintenance. seems like really just website down...
