Fuel injector cleaner
Beepok
Since u so rich Just change all 12 injectors. Also change the fuel rail and regulator. Should be about $20k for it only
americanhippo
Just bought a techron fuel cleaner for 45rm. About same price in sg. Going to try it soon
koolaid
why need to use injector cleaners ts? ur car feels sluggish?
pump full tank caltex and drive at 180kmh on nshwy for 30 mins or so... may be u can feel a bit of difference after that.
if u r thinking of using techron concentrated plus, can consider buying it in msia caltex station. that's what my friend did a few months ago. he said its cheaper than buying it in sg.
tankgunner
Mentor
Waste money one.
Just go nshy and floor it will do.
You sure feeling your car light light.
New Eden
Use cowtech techron every 5000km last time i use stp every 4 tanks use 1 bottle. Stupiak sia. That 1 useless.
Cowtech really good.
New Eden
Immediate effect is you will feel your pedal less heavy and engine less drags. Just try 1 bottle. Dont just hear me say.
Alphas
Only when there is carbon buildup, then there is a noticeable recovery of loss power. But don't rely on feel, get a small boroscope to check first.
New Eden
Wah kns. How can outside sell cheaper than cowtech stations????
Expert
petrol itself is a cleaning agent liao... :s22:
the one you should be changing is your fuel filter. :s22:
