Full immersive water cooling
Humster
You want can do Mineral oil cooling, which is available for long time liao.
wwenze
The difference is datacenter gets their own bulk purchase and their internal support department and can liaise with CPU manufacturer regarding RMA
hg2
So it will not corrode, short-circuit any components and can transfer heats to keep everything cool... ?
Really did not know this "trade secret" leh!
jack-320
Just be aware that this will happen
When it is no longer soaked
zleipnir
hg2
LP PL ?
guarantee 6mnths later leak... as the heat&pressue will disintegrate the seals.....
Fatfool
The article links to cooling with low boiling point fluids. Not mineral oil.
But in any case, this is something I'd be staying way away from. Liquid cooling works well enough and you can just get a passive rad if you're not acustomed to the noise.
Why have a freaking tank of liquid on your desk?!? It's going to release all the heat into your room anyway
