G50 form pls help bros
sohcheekeong
The STE hiring manager request me to start work on next monday but my G50 clearance haven't done so. Does I required to clear before start work? Normally the processing take how long to clear as today I just request for the clearance form. Thanks
No need to wait for G50 clearance, you may start work next Monday.
My situation was pretty much similar to yours. I applied and got a job in a ST company, was requested to fill up the G50 like your case. I started working in ST and left afterwards and never knew the outcome of the G50.
As long as you can continue to work and get your pay, don't think you need to think too much about the G50.
matey1982
do u think we are STE HR dept?
y dont u ask them
reddevil0728
What kind of advice? But my post must required a Singaporean but my spouse is a PR..
So what is g50 proceesing time?
I pity STE shareholders that they hire someone like you.
1) STE is your employer
2) The reason you need G50 clearance is because that's what your employer requires for you to do your job.
3) Instead of asking your employer whether you can start work without clearing G50, you are asking the forum?
If you think it make sense, then STE is doomed to have you already. Furthermore, you don't even know what kind of advice you should ask and your engrish is the best. Seriously.
I don't see how you can possibly claim for sure that there is no need to wait for G50 since you are not in the same exact position as TS. You may be in similar position, but at the end of the day, it is for his employer to advise him directly.
You can say he can start work, doesn't mean his employer must allow it.
Chao_Ah_Tiong
I worked at STE for a short while also as a contract staff last time and for my case only after I started work then they asked me to fill the G50 form but then before I submitted my G50 form I accepted another permanent job offer and quited STE.
Don't know whether the process is depends on individual department or they have changed the way they handle the G50 clearance but think it is better if you can enquire STE regarding this.
As for the processing time if I am not wrong for Cat 2A it will take 3 weeks at least. As for whether having a SPR spouse will affect your G50 application only the peeps at Military Security Department knows.
softwareengineer
I dont think it is nothing I can do. If someone who was gone through this CAT 2A says that naturalized citizens are not eligible then I would not take up the offer.
reddevil0728
if it is a job offer... the very fact that they are offering you means got chance of succeeding right? as with anything, if it is going to be 100% confirmed + chop, then no point applying, just given only...
if you are not even eligible, they wouldn't even let you apply/offer you.
Chao_Ah_Tiong
Any idea if naturalized SG Citizen will be eligible for CAT 2A clearance? Thanks
This one only MSD people knows but then I do see some new citizens (from PRC) when I worked in DSO and ST a few years ago although they jobscope might not involve sensitive works. Also in my army reservist (armour which is quite a sensitive vocation) there were a few new citizens from Malaysia and China as well.
softwareengineer
Thanks for the information
