Galaxy Note Accessories
Eunhoon
Do a search for Nillkin TPU Gel case (comes with free screen protector & screen cleaner). Very nicely made case which fits well (can't vouch for the screen protector as already have a different one installed), no issues with the power button & is value for money too. :)
My SGP Capsules works great for me though, No problem with the power button ;) will post picture in a while, the Only downside for me was there no space in between the Speakers and the surface you place at, making volume trap within the case happens that my vibration broken making it worse for me :(
and its SGP Screen Protector Crystal edition (the same one that came with the Ultra Capsule) works great!
Im using the metal battery cover now, just bought from soyabeanmilkdrink at $17 each. I bought the Gun metal colour and 1 Metallic red colour.
Some review: I found the case to be of solid build, much more sturdy than the stock flimsy cover. It adds slight weight to the phone due to the metal material. The phone feels better in my hand now.
Just to add, it adds like 1mm to the thickness of the phone, makes it feels as though theres a back case attached to the phone. Now the camera module is recessed, will not touch the table when I put it down.
Overall a good buy, no need to buy casing liao:s13:
was just thinking what if you drop your phone and the corners are not protected? case would still be the better choice i guess? or a combination of both =:p
Eunhoon
Here's my SGP Ultra Capsule (Tender blue) :angel:
marcus70
actually there is someone.... can't recall his name....is selling the battery,he is oso the one selling the aluminium cover,just a few pages back
Tuakong
Whoa, the aluminum battery covers look pretty good in real life! I think the main reason is because it covers the entire back, so the look is more uniform.
The quality of the cover for the 5000mAh extend battery is also pretty decent actually. It's not jet black, but rather has a dark blue tint. Can't really see it in pictures though..
Are these to replace the stock back cover housing ? If yes then I am interested
dogbomber
After checking on so many cases (flip and non flip), finally I got my ideal case for SNOTE in Malaysia. And I would like to share with everyone here:
Advantage:
1. It covers all the edges of Snote.
2. Power and Volumn Buttons, although covered, are still sensitive enough to be controlled.
3. It leaves space for SPEN, unlike other expensive Flipcase.
4. It has stylish design on the backcover and have some GRIP Buttons at the both ends
for us to hold it properly.
5. Most importantly, it has button for us to insert handstrip, which is a must must for me.
Disadvantage:
1. The hole for volumn is slight misaligned, but it will not impact the volumn output.
I am using NOKIA Handstrip in the picture, and I use alcohol liquid to remove Working of Nokia.
And now. I decide to look for a Pounch that can fit this in and I found these 2:
(Neoprene Water Resistant)Soft Pouch Case for Samsung galaxy Note GT-N7000 i9220 | eBay
White ( TPU Gel + Black Neoprene ) Case Cover Pouch fr Samsung Galaxy Note N7000 | eBay
I am not sure if with the bumper on, they can be fit in the pouch properly.
Please share your thoughts.
tikokia
i doubt so unless e metalic cover is the same thickness.. which i doubt so also... :p
not about thickness ba.. u see the bottom part of the bumper (back plate), it sort of holds the bottom part in, unlike the other bumpers which just goes around the edges of the phone allowing covers to be swapped
Big John
ya bro... if e thickness of e metallic batt cover is the same as e original, then it will fit. but if its thicker then cannot bah...
davi502
Advantage:
Disadvantage:
Looks very similar to the ones on dealextreme.
How much did you pay?
