Galaxy Note Accessories
~WindzStriker~
wow.....i look at Deadboy's MO and im the only one ordering Glider thus far......did anyone order fr ebay instead???.....deadboy's MO4 may close soon.....dont let me be the only guinea pig leh :s13::o
I like the Glider to the max, i meant the champagn Gold color one
but i see the price :s7::s7::s7:
Eunhoon
:o:o
looks great on white ;)
but dont get what u mean on your sound being trapped ?
Thank you! i really loved how it looks on my Note :love:
what i meant was when you place your phone on the desk flat on its back with original cover, there's this Bump pushing it up from the surface to allow the sound to travel out.
but upon putting on my case, when leaving it on the desk flat as usual will kinda re bounce the sound back to the speaker as there's no bump to push it up from the surface of the desk.. which i think most case have this problem too?
since my vibration is broken :( i need the sound to travel if i left my phone in my room ..
Akai Ryu
was just wondering if you press harder on the screen will the whole thing just fell of the surface?
Edit: from Onna webby>>> Before you order please note that you should not use the Oona to mount your smartphone any higher then you're willing to have it fall
Don't you think the Note might be a bit too heavy for the suction cups? :o
yes got consider those possible issues, but i like the portability and will most likely use it on desk :o
Thanks i will put some thoughts into it again
~WindzStriker~
oh got it
which case eliminate this problem den i wonder:s11:
~WindzStriker~
guinea pig r kindda cute :o
soyabeanmilkdrink
This is what the aluminum bumper sold at SLS looks like. Slide to lock the bumper in place, and no branding printed on the bumper itself.
However, like the one sold on obostore, it was somehow designed like the bumper for SGS2, with the bottom portion covered. This means that 3rd party battery covers cannot be used, since it won't be able to accommodate the extra 1-2mm thickness of the cover.
The inner surface is bare, so you got to DIY and line it with some felt cloth to prevent scratching and also make it fit more snugly.
imacbie
urs pretty well done too! haha! finally met someone who will diy cf on e phone... naise!
i did my money clip/wallet also.
then those around me thought i changed to a new one lol
nicer texture than the fake leather
SKinny86
How did your vibration broke ah? nv send for rma?
Big John
Holy crap!!! How you DIY one?? So nice!!! and what does CF stands for???
i cut out a piece of carbon fiber stick slightly bigger than cover, paste it, than trim e edges wif a handicraft knife (buy @ Daiso).
