Galaxy Note Accessories
Akai Ryu
this looks good for a leather pu battery cover.
u wanna order in? Same or close price as alu iirc ;)
got wood grain etc too
summer_dell
hi guys
I am interested in getting one anymode bumper case for my SGN...
Anyone have brand new for sale? Or any place where i can buy in sg?
marcus70
mine is sandisk but iirc kingston is cheaper by 50c or $1.
hi bro just to check with you ,ur sandisk is class4 cos mine was class 4 as claim by the seller but i think is just a class 2,there is no indication on it when i tried to look at it
Shada817
bro u go see ur microsd there should be a 4 inside a character C.
tsetze
Although i havent got my Note yet...but i already got 3 mercury case.. i bought 1 red at first.. then i find that the quality is really good... the cut out also very good... then i bought another white and another green...
By the way.. i bought from oversea, China...
:s13:
hmm now gmarket sells around 12$ for 2 including shipping. but the thing is i saw from previous pages that the case might actually squeeze the screen protector off and cause bubbles.
anyone with that problem?
~WindzStriker~
64gb microSD card confirm working on Note hor ?
btw where u all purchase your memory cards ? ebay ? gmarket ? or ?
tsetze
class 4 or class 10?
does class 10 and 4 makes a difference for the note?
ST delivering note coming friday, anybody can tell me the price of a 16gb out there roughly how much? if i happen to see it and the price vary not a lot den guess i'll just buy it
Shada817
if you are looking for class 4. you can check it out at videopro at sls, they normally sell at reasonable price for microsd but the last time I went to buy microsd they have limited stock.
http://www.videopro.com.sg/getdata.php?id=286
sandisk 16gb class 4: $23.5
Shada817
bro one more thing if there is no indication. u can download this app from market "SD Tools" and try to run speed test. after test is done look at ur writing speed. if its class 4 it should be around 4mb/s to 5mb/s. but how accurate is the apps I cant guarantee but for me its quite accurate.
