Galaxy Note Accessories
gerald27
Share wif uall moi impromptu Stormtrooper kick stand :s13::o
fwah ... cute neh :o
your storm trooper so big ah ~
otaku7
just took over the silver bumper from tikokia.
Some tips for those using the bumpers:
Some times it may be loose on the top sliding frame.
Especially when pressing the edge and it might slide back out.
But just take out the frame and bend it inwards.
This will create some tension, which will hold the thing tight.
Iynereh
I read the sgp capsule got the power button sensitive issue. Any other brand to recommend? Thanks
i already have problem with the power button keep pressing it unnecessarily. i feel that the power button should be placed on top. not so easily pressed.
I agree too! The power button should be at the top. Even without sgp capsule i keep pressing it by accident.
rubric
I got my Design Craft case from p2o at Burlington Square. It's made in Korea and has a slim profile, but a little thicker at the corners than SGP's ultra thin air. It's close to what you can see here for the SGS2: Design Craft+. Most--but not all--of the back is covered with squares angled diagonally (like diamonds). The shop only has two colours: white and black, and each comes with free screen protector and cloth.
So far I like it quite a lot as I prefer hard--but slightly flexible--plastic cases to TPU, silicone and flip cases. :)
mohdFaiz
any ideas where to get cheap cases locally? :o
i see all of u post are those need to ship ones.
i prefer to try it on before buying :o
currently using sgp ultra capsule cos thats the only one that i can find =\
thanks in advance!
cyrilng
thanks in advance!
At Toa Payoh, at one of the many phones shops there I saw one that had some TPU? cases that were $10 but I can't recall exactly where....:o
cyrilng
Does anyone have any issues so far with signal degradation/loss when using aluminium back covers?
cyrilng
Still waiting for my cover to arrive, but how bad it is for your case?
Had to send mine for replacement due to damage in transit. :( Just wanted to know so far if anyone has noticed any signal strength loss when in use?
KYLee
Guys need some help here, has anyone of your SGP ultra Optics screen protector turned blue? few pages back i mentioned mine is having blue tint, today it turn even more bluish till the blue is very obvious. first, i use a black soft material pouch and i have tried wiping the inside of the pouch with tissue to see if it turns blue but it did not. and secondly, i didn't wear any blue shirt/jeans this 2 days. only on friday which i bought the SP but it wasn't blue then and it was in my pouch.
Check out this 2 pictures.
is it possible the SP changed it's color?
I have been thinking what could have made my SP blue but couldn't find any answer.. should i bring down to DG vivo for a replacement since its only bought 2 days ago and i seriously think i did nothing to have it turned blue.
cyrilng
You sure it's not from the pouch? Did you try putting any other similar light colored object in the pouch over a period of time in close contact to see if there was any transferrence? Heat could be a factor too. My wife used kept her Note in a black neoprene pouch & the light blue TPU gel case's corners were slightly stained after some time.
I guess best thing to do would be to bring it back.
mohdFaiz
Wah $10 is really cheap eh. If u do happen to see other shops / been to that place again pls sic here for all :D
TIA!
~WindzStriker~
:eek::eek::eek:
bring it and exchange ba
cyrilng
TIA!
Roughly recall that it's either one of those along the row of shops on the left opposite Burger King & further down or towards the back section along that row where there a some food stalls & that the shop is near the corner. :s13:
cyrilng
if gt problems, all the Samsung Wave series and HTC phones and RAZR can throw away liao
I mean those replacement battery back covers lah. Heard that aluminium bumpers may cause some signal issues perhaps due to proximity to antenna so was wondering if AL back covers might too. :s22:
KYLee
Im pretty sure its not the pouch, i did try rubbing tissue paper on the inside of the pouch for about a min and it came out white. strangely, i only used this SP for 2 days and in fact, it wasn't in the pouch most of the time since i used it very often in the day and i don't leave my phone in the pouch at night.
:eek::eek::eek:
i was shocked how fast this thing turned blue too. shall go down tomorrow.
Shada817
FYI, I went down to DG vivo yesterday to get SGP screen protector but all of them out of stock. end up I went to far east to get.
Shada817
damage in transit because of the aluminium back cover? thats bad. I ordered mine and its on the way. :(
Big John
izit difficult to press e power n volume wif e case on?
