Galaxy Note Accessories
Akai Ryu
I ish NPNT now wor. Lol
I try after it arrives~
oh i tot u got it already, the black capdase is who huh? Anyway would appreciate feedback on extraction of Spen, worried that the thickness and opening of the case will hinder it
Akai Ryu
Any S2 user have tried this screen protector before any feedback ?
SGP Samsung Galaxy S2 Screen Protector Glas Series
hope they release this for SGN.
• High-tension tempered glass:
The SGP GLAS is chemically reinforced glass that maintains clear image quality while it protects your screen from scratches and external shock.
• Color Printing:
You can easily personalize the outer edges of your Galaxy S2 with
any of the colors we have available. If you use your GLAS with and SGP case,
you can also change the color of the sides and back of your phone and
give it a new, unique look.
• Oleophobic Coating:
The oleophobic Coating prevents oil contamination and figerprints
and is easy to polish and clean.
• Thin Thickness:
The SGP GLAS is made of glassware, but the 0.4mm thickness maintains
the Galaxy S2's liquid crystal display and smooth surface.
• Anti-Shatter Film:
When hit with a big external shock, the SGP GLAS may crack,
but it does not shatter and is safer to use than most other glass products.
• Easy Installation:
The GLAS is easier to install the PET film, and does not create bubbles,
and the Fluorine coating allows for eash removal.
• Designed by SGP in California, USA
• Made by SGP in Korea
Seen pic of shattered SGP glass. Next closest is this 3M glass (?) which is not available on GM KR, much less outside of KR.....then again the 3M logo is a turn off
http://3mmania.com/shop/shopdetail.html?branduid=355699&xcode=001&mcode=002&scode=&type=X&search=&sort=order
DarkFord
I use the tip of my fingernail to pull it out, no sweat.
V
victorlht88
Guest
• Color Printing:
• Thin Thickness:
Resulted in touchscreen issues during charging initially. It was fixed by one of the custom kernels in the end.
