Galaxy Note Accessories
theory_87
myrin still better lah
It really looks good.. but too bad the inability to use with case... wondering can fit with original gulp case or the ultra slim case im using now...
Akai Ryu
u guys know what gn's bezel is made of? issit anodized alu?
need to know coz wanna try and remove fine scratch.
thinking of trying toothpaste, autosol or some metal polishing cloth
Just polished the scratched area of my bezel with autosol and it works! :s12:
Seems like although the bezel scratch easily, its also easy to remove.
The scratch on mine very fine, those of you who scratch the charging port bezel area while charging should know what i mean. Any other type of scratch im not sure whether can remove with autosol anot.
Still have not figure out a solution to remove stain on my SGP ultra capsule :(
cyrilng
Wah SGP Ultra Capsule case also gets stained? Thought it only happens to those cheapo ones...
damienism
autosol is of slight abrasive nature right? u used glasse microfibre cloth?
marcus70
davi502
Maybe was sold out? I got it from the mobile accessories store near the uob atm on level 4.
