Galaxy Note Accessories
Akai Ryu
:s22::s13::spin:
Akai Ryu
hope there's gonna be a bookbook for sgn soon...closest and of good quality is valentinus but not as fun
Akai Ryu
Just polished the scratched area of my bezel with autosol and it works! :s12:
Seems like although the bezel scratch easily, its also easy to remove.
The scratch on mine very fine, those of you who scratch the charging port bezel area while charging should know what i mean. Any other type of scratch im not sure whether can remove with autosol anot.
Still have not figure out a solution to remove stain on my SGP ultra capsule :(
just googled, gonna try bleach on white TPU stain soon
darknez
so u gonna paste urself? :D
After trying to paste this SP myself, I really appreciate Vulpix's incredibly expert skill. :p
"bookbook"?! You mean like the one that you, or someone else, put up a few pages ago? May be should get the Holy Bible version..... :D
larrylaw5
Got this and deliver after 1 week.. Great quality and touch.
but the workmanship of glue is not that good.
Jhyun
Is it very hard to apply compared to normal SP?
I tried ordering XtremeGuard, those Invisible shield type.... gave up after 20 mins of wet application.... normal ones are ok though...
darknez
This one is a dry apply. It is infact very easy to install as it is thick enough not to flex and bend when applying. My issue is.... I'm long-sighted, can't fit the sp to the screen properly.
Jhyun
Okkkaaayyyy! One more SP for consideration :D
kottty
just received my metalic case from ebay..take out my back cover the batt not loose still tight..quite good build quality..very satisfied..
Akai Ryu
The one i put up a few pages ago is more of a book holder, have alotta DIY on how to do it, have a site to order custom even.
there's one for S2 but most likely inspired than fr bookbook
