Galaxy Note Accessories
Akai Ryu
mine dun have this kind of problem .. start using this stylus from december till now still okay .. always put in my shirt pocket .. no lint, no sticky feel ..
i have lenovo mouse which has the same problem but my mouse already like 3 - 4 years old, the skin peels off .. what i did, just scrap off the skin using cutter .. then the plastic will be okay .. those sticky thing is just the skin layer of it .. you can scrap off .. after the skin layer gone, it will be just hard solid plastic ..
gd for u :D
i tried removing and end up threw away one, this is my 2nd lenovo stylus coz i wanted to confirm
fortunately got it cheap fr sungei road :o
Akai Ryu
keyboard DIY Mod
:eek::eek:
°¶·°½Ã³ëÆ® °ø½Ä1È£ »ç¿ëÀÚ¸ðÀÓ-°¶·°½Ã³ëÆ®/°¶·°½ÃÅÇ7.7/¼¿·Ï½º :: ³×À̹ö Ä«Æä
fade_white
Does anyone know of anyone selling tpu / silicone-like bumper cases like those they sell for iPhones?
tekster
i got 3M privacy SP for $28. it is 2 way not 4 way.
pls note that, there will be double image if you switch to high brightness in a dark area but i usually set brightness to minimum so its ok for me & i noticed a few days ago that when under bright sun & max brightness, double image not visible. Overall I am still ok with the SP quality & feel. this SP is not for you if you want image quality, after all it is a privacy SP.
I will post pictures of the SP & images if I can these few days.
yea, quite anal. i was expecting 4-way privacy. didn't expect it was only 2 way. damn man. feel like i've wasted my money.
after seeing my friend with normal SP, i feel like i've wasted the AMOLED bright and beautiful colors. :(
daygain
Clarivue privacy SP advertises that it works as a 4 way privacy SP.
Any idea where to buy 3M privacy SP for only $28?
ryker
Not really..still okay.. Initially bot super thin case to be used with metal bumper but cannot fit in .. now using iroo case fit nicely .. the top bezel and corners also protected
with the extra thin cover, won't it be very thick?
touchme
Hi all
anyone can recommend Iwhere I can buy the vehicle dock for the note?
thanks!
My note is with jelly casing. Looking for dashboard holder any recommendation?
small, cheap and ultra-sturdy, rotatable, easy/fast to secure and remove. usable for any phones with/wo case..Clearance for power/volume buttons, Adhesive or vent mountin (not windscreen), short stem.
Ordering another one myself, $10 to tumpang.
