Galaxy Note Accessories
V
victorlht88
Guest
Btw, does the sgp glas have the same issue as it was on the sgs2 where the sensitivity Of the touchscreen is affected when charging?
If it's OK, I might consider doing a mo for it.
Akai Ryu
wow custom "ezlink" RFID mod :eek::eek:
if only we got such custom mod for sale locally :(
Akai Ryu
was there a way to rectify this problem on S2?
Akai Ryu
huh the original flip case can sleep the phone like ipad's smart cover?
think that was misinformation
description fr another site
Brushed Samsung Galaxy Note i9220 N7000 Housing with Carbon Fiber Flip Cover
The Newest design housing with front protective cover for Samsung Galaxy Note
The grey housing is made of PC material with Metal brushed surface
The black carbon fiber cover is made of PU material, which sheilds your Galaxy Note from those daily scraps and bumps
Replace your broken or scratched back cover housing with a new one
Highly recommend professional installation. We will not be held responsible for any damages to your cellphone/mobile phone that you may cause during the changing of replacement parts
basically a metallic back cover with flip
touchme
So the wire ring enables reading of ezlink card when placed behind phone?
Got specify special material for wire or just copper will do?
Akai Ryu
cyrilng
If not wrong, it's just selling the gut of RFID attached onto cover.
Internally it's how it look like, but with less plastic maybe able to work
edited:
less plastic as in remove layer of the ezlink card
Using My iPhone as an EZ-Link Card
I think the guy actually stripped away all the plastic leaving behind just the copper wire antenna, cashcard & RFID chip right?
astroboy37
anyone knows where i can buy those screen protectors that has perfect fit (just like the mercury screen protector below). i would like a matt SP.
I noticed that the ones selling outside has a very horrible cut, with a big cut on the top. i would prefer a SP that has precise cuts, with 3 holes on top (see pic).
astroboy37
Does anyone know where I can buy the Zenus Case for the Galaxy Note. Saw it at the IT show but regret not buying it then. Could not find in Sim Lim either.
Here is the sample picture from Gmarket. Thanks in advance.
MP3 / Mobile / eBook - ZENUS SAMSUNG GALAXY NOTE MASSTIGE COLOR EDGE D...
think gmarket sells the cheapest already. the cheapest i saw was like $52 inc shipping. and if the price is $52, you can still use normal coupons and double coupons to offset your purchase. isnt it better? haha. but the catch is that you gotta wait 2-3weeks
yellowtang67
it was selling at IT show for $51, plus no need to wait 2 weeks. The booth that was selling it was called "Twister", but cant seem to find their address.
cyrilng
Looks like one I saw earlier for SGSII. Looks good as it can fit the Note with case on (so should definitely fit my Samsung Infuse 4G with case on too! haha)
Still waiting for the RuNGo one I ordered....
Got my Run&Go Micro 5 pin dock cradle today from New Desk Dock/Cradle Sync Charger Samsung Galaxy Note FreeShipping | eBay Took about 1.5 weeks to reach here from Korea. :)
Very compact & has a small footprint. Comes with two small foam pads to stick onto the cradle to cushion your phone if you want to when docked. The base has four rubber pads to stabilize the cradle & prevent it from slipping about on smooth surfaces. The cradle has 2 slim slots at the back that just function as namecard holders. No cable is included & there are no indicator LEDs on the cradle either.
Most importantly it does fit the Galaxy Note with a 'normal' TPU case on & is able to both charge & sync the device. (I don't have any other case to test it with.) It also should fit other similar devices as it is a 'universal' cradle since both ends of the main slot where the phone sits are open-ended. My Samsung Infuse 4G with Nillkin TPU case fits & is able to charge as well (although I have to press down on the phone if I want it to sync.)
Overall, not a bad buy for S$23.90 but not as versatile as the Myrin Crown stand which does come with it's own cable & is able to hold the Note in both vertical or horizontal position & with the option of having it connected or not in the vertical position but which takes up more desk space. Myrin Sync & Charge Dock Crown Stand for Galaxy note(Black) | eBay
V
victorlht88
Guest
don't waste your $$ on that. I am using the coloured anti glare screen protector from my supplier. quality is exceptionally good and doesn't scratch easily. GPGT.
