Galaxy Note Accessories
Akai Ryu
Samsung Galaxy Note Trident Kraken & Aegis AMS Cases Coming Soon! | TechieWarehouse.com Blog
otterbox really letting other brand fill up its niche
AEGIS for Galaxy Note - Trident Case Europe
KRAKEN AMS for Galaxy Note - Trident Case Europe
Akai Ryu
My Sweet Armor Gnote finally reached! :s12: :s12:
later than test if its the real deal or a bummer *touch wood*
Akai Ryu
How is it? :flash:
This bumper is definitely the real deal :s12: i am usually sceptical but this might just be the case that will last me till the next phone :s12:
Inside is well padded
My first unmounted test, sit well in it
Never thought i would be using the original back cover ever since Ultra capsule and some other case
Quick access to battery for OTG changing? No problem whooooohooooooooo!!!
Akai Ryu
this is one of my criteria for any new case, must be able to fit the micro usb cap....slightly harder to remove but it actually solve the problem i had when using ultra capsule with this cap coz it tend to drop off when i remove the capsule....fortunately always manage to find it back
no problem with the audio jack cap too
quick extraction of Spen? Checked!
I did not take pic of the power button and volume rocker, but the button cap that came with sweet armor is very responsive!!!
For those who read the XDA review, its TRUE! although sweet armor slightly widen ur note but the groove behind actually made it easier for single handed operation, guess i can keep my bunker ring for now.
If there's any potential problem, it might be the audio jack, i use stock earpiece and Jabra so no problem. Some other earpiece may need extension (?)....and of course, this was not cheap though it was on Sale........but im still loving this bumper!!!!!!! Its like handling a new phone!!!!!!
Jhyun
Is this picture accurate? Or does the phone sit inside the bumper like the SZLF?
Cos my requirement is the front part of the casing must be slightly higher than the glass.... Bad experiences with big glass dropping and showing me spiderman's web, even if it's gorilla.:(
Akai Ryu
this pic is unmounted yet :o i did not take pic of the front "frame, maybe u can view better pic fr the XDA review
Once mounted, the bumper and the phone feels unified, yes front part is slightly higher (lip) but not to the extent which will hinder using the screen at the edge
Edited: i did not use SZLF, but Glider which should be the same....Glider ish i put on try i remove the next min........
where and how much does the sweet armour case cost btw?
also, where did you get your headphone and mini usb caps?
the tpu clear case which i bought since months ago has turned slightly yellowish and i'm thinking of purchasing a nicer looking case.
thanks!
Akai Ryu
Akai Ryu
