GALAXY NOTE II ACCESSORIES
evermind
hmm anyone use portable charger to charge note 2?
i used mine but apparently first few secs can charge then after which stop charging
i used on my gf s3 same thing
cant be the usb cable right? cos i used the original cable to poke inside my portable charger.
it works on my s2 though
i tried. killed my portable battery in that few seconds. fully charged 5600mAh portable charger killed/drained in less than a minute.
Sinkie
Wah go where hoot?
Holiday plaza..
The USB cable is quite loose, I should have tested it there. Matt display screen protector looks a bargain.
It's fortunate I didn't buy the fake oem Samsung flip cover.. Haha
evermind
ALacs
does anyone know if samsung singapore will bring in the original note 2 protective cover+?
asked the jurong point samsung center staff, the centre supposedly newly reopened, but the staff does not seem to know anything.
SuperDecker
it's impossible to be end of lifespan. in my case killed as in totally drained the battery. and my note 2 didn't even increase a single percent.
wah i just bought a pro charger 12000mah battery to charge my note 2, only did one charge so far, hope it doesn't fry my note 2...which portable battery charger u using?
Akai Ryu
037DF4385098179B28023C
theory_87
I guess your portable charger is outputting 0.5mah only... It will never charge Note 2...
Skyy
I used a 10000mah one, can charge from 50% onwards to 100% no problem.
i1magic
Just received my gmarket hoot. :D
Will be testing out how well it works tomorrow.
I received similar package from eBay.
The batteries last about 55%-60% of what the stock battery can last. IMHO is ok for the price we paid.
Do post your findings.
SuperDecker
Specs looks good.
Stock Note 2 charger takes slightly over 2hrs to fully charge the battery in the phone.
Could you advice us how long does it take for this one?
this one can go up to 3A, the stock charger is 2A, will this fry anything..?
