GALAXY NOTE II ACCESSORIES
Akai Ryu
fabianlau
Hi, Anyone know where to buy the back cover door locally. Thank you.
Gmarket .. I have one used 2 wk.. still good condition no scratch.. if u want pm me.. the back look like ip5 two tone .. black and sliver
kero89
Was talking to my friend about my scary encounter about posting flip casing here in HWZ and how I became a target for using a flip casing.
So we went on talking about screen protectors for Note II. Well I casually commented that after my GlassZone failed me completely and Spigen not doing Glas.T for Note II due to the curve nature of the screen sides, he actually surprised me with something when I met him again a few days ago.
All hail the new clear-transparent-smaller-than-the-screen Glass Protector, which has erm, no brand! Lying on my Toy Story board!
Disclaimer: If you don't use screen protector or find screen protector a hassel, keep that to yourself and treat this post as transparent.
Application was as easy as say Spigen?
It is cut smaller than usual, especially at the top, and it does utilise the same adhesive deployed on Spigen Glas.T range. Once laid on top, a simple press in the centre will let the glass adhere to the screen. Virtually, ok there was 1 bubble which I got rid of after a few press.
It is a couple of mm thick! So an aluminium button will work?
Around the sides are rounded, sounds familiar uh?
Overall the feel is just right, and whatever Spigen brought it to Glas.T for Note I, the same standard applies here for this brandless glass.
Summary
- Clear
- Just like glass
- Just like touching your naked screen
- Does not affect SPen
- 1 Application, got it wrong and you are screwed
arcanehacker
Does anyone have the original Spare Battery Kit?
Just got it yesterday. Charged the new battery inside all night and LED was green this morning. Took the spare battery out and fitted in the Note II and phone showed battery was only 70% full.
Then I tried putting the original battery which was 77% full in the charger LED was red for a couple of minutes and turned green. I don't believe it charges so fast. It probably turns green before fully charged.
Anyone else has the same problem?
Check or change the USB cable thats connected to the battery charger.
sgbdk
eh seriously... show all the note 2 casing/accessories you all got till date leh.. lol
exclude 1 x replacement note 2 defender and 1 x bodyglove series casing for note 2(on the way lol)
spend so much on casing and sp
zacky1223
wall charger
Hi to all bros and sis here i would like to check which usb wall charger plug can i get for note 2 ? other than the original samsung which is very ex :(
selenger
Nice case but it would be too much of a trouble if I want to change battery
need to unscrew at the bottom of the case , just to remove that metal plate
and take out battery to replace another one.
I got mine from Gmarket SG. $12 and charging output 2A, charging time same as original charger.
It has 4 usb outlets. But must use same usb cable,, if not slow.
Luckily I got spare usb cable for my old kindle.
