Galaxy S6 Edge with Singtel - Poor data connection
JetJetJet
I recently recontracted with Singtel and got the S6 Edge. After upgrade, I got only GPRS connection most of the time every where. Before upgrade, I can get at least 3G most of the time.
Not sure whether it's the phone of Singtel problem.
I have written to Singtel and waiting for reply.
Does anyone have the same issue?
seller4
Get a SIM from another telco n try. Borrow from friend or family.
If still bad reception, then it could be that the phone is faulty.
If the reception got better, then it is Singtel issue.
shager
Thought SingTel is having 3G/4G issue presently? Tried with another telco?
Zaalaa
yeah same with yours.
few days already. tried to use google map, knn only "G".
end up use my iphone 6+.
seriously. can't get it up to 4G or even 3G at all.
at first thought its singtel but after that realised maybe it's s6 afterall.
kenchi
noting wrong with tyor phone
its singtel issue
no issue on my m1 and hub line
porcu
I realised the problem recently also. Seems to be connected on H+ more than 4G.
Anyway to force 4G?
MyiP6+ on M1 is connected on 4G all the time.
WWE_Fan
Strange. I also using s6 edge on singtel. Data connection is good at Ang Mo Kio (where i work), and travelling back to Woodlands (home).
Was in town (Orchard) over the weekend. Also no issue.
Where were you at?
kirium76
Where were you at?
Try reselect the network. Switch to GSM first then reselect LTE. It works for me.
Lucky177
I'm on Singtel. Most of the time is 4G. But I'm using Note4.
Not sure whether this info is useful for u?
Sent from Android Mobile using GAGT
JetJetJet
Thanks for all the replies and suggestions. Singtel simply asked me to try on other phone blah blah, but I can't try on my previous S4, since the new sim card is nano sim :(
Sometimes it can connect to 4G+, but it stays on G more often. I am at AMK area. I will try to plug out and plug in the sim card again and try my luck.
