Game recording using FRAPS/Shadowplay - Not compatible with Higher resolution?
artyboy
Don't know if its the right place to post this but I can no longer use FRAPS or Nvidia's own Shadowplay to record games being played. It was fine when I was playing games at 1080p but now the recording stutters badly when I try to record games playing at 3440x1440 resolution (ultra-wide). I've tried turning off G-Sync and change the refresh rate from 100hz to 60hz but it still stutters like crazy. Is there a resolution limit to FRAPS/Shadowplay recording? I googled but couldn't find the answer.
wwenze
Fraps @ 3440x1440... can your HDD handle 300MB/s continuous? Don't think so.
And SSD can be even worse than HDD in this aspect, their write speed will plummet after the first few GB is used up.
That's why need to use Shadowplay and use hardware H.264 encoding
