Gear S3 is announced.
renfred89
I was prompted by the gear app to do an update for my Non LTE S3.
Is there a log on whats the update about?
Sent from 你妈妈喊你回家吃饭去 using GAGT
Log is pasted a few pages ago. Do check.
Update includes new apps, new interface and Tizen 3.0
lycanboy
I have updated to that version. Apparently now there is another update. Do check you Gear app. It's prompting me to update again.
renfred89
I see.. perhaps it fixes the battery drain issue? You press download then can see changelog liao..
Edit: only gear plugin update.. :) before jan 2018, we should see a new update for gear s3 to fix battery issue..
evq
samsung already rolled out fix for the battery issue, but only for certain country as for now.
joesph
last time hot also can charge 100%, now hot about 80% max
Sent from Samsung SM-G950F using GAGT
joesph
spelljammer72
I'm trying to add a credit card into the Samsung pay for my gear s3 and getting gear not responding, try again.
Bought my gear s3 from Malaysia though. Any problem adding Singapore credit card?
PPkiller
It didn't fix the problem for me.. battery still get overheated.. and it will discharge while charging.. pui...
