AWholeNewWorld
- Aug 1, 2009
That means I've to either port over to singtel or starhub for this.
no need LTE model I think can tooBuy LTE model but use bluetooth connection for the time being?
I am facing BT reconnecting issue. Once the watch is disconnected due to out of range, it will not connect again once within range.
I tried to connect manually thru the gear app without success. The only way is to restart the phone then the connection is ok.
Anyone also facing the same issue? Any solution to it? TIA.
I have the same issue when it paired with my Xiaomi phone. after changing to Samsung no issue.
The new update to fix the battery is out. Will monitor. Best companion device till date!
u got the update already?
Yup. Wi-Fi version here
The firmware.. Didn't improve it.. In fact my s3 is pretty gg now.. Full drain in 4 to 5 hours
I am pairing it with S8+
