Genshin Impact
nasilemak100
i would prefer to play for mobile game with "energy/stamina" as it is less time consuming.
this genshin impact is like mmorpg....if jobless or full-time students then can play it to fullest.
so dun think i gonna try
Zappalapa
some of the posts here really lol.
just chill and enjoy the game at your own pace. no pvp. f2p also can clear the game.
ErinaMizuno
Venti so good?
I'm AR16 now, started yesterday and my current roster is Fischl, Barbara, Xiangling and Chongyun. Haven't had difficulty with anything so far.
Venti is good when u reach ar20 and above and need to fight the dungeons. This is becoz most of the challenges are “ kill xx enemies within xx mins”. And the faster u kill the better rewards. All his skills are AOE and they will suck the enemies for a short time
d515s23
it's mainly a single player action rpg, everything is at you own pace, there's nothing to rush. stop whenever you want, and pick up right where you left off, nobody is there to steal your loot or kill your steal
Ctrl_Alt_Del
Keep seeing ads spam for this game.
The linkway walls of serangoon mrt station between circle line and nel and glass wall of bishan circle line platform are covered with the characters vinyl wallpaper.
There is event for player to scan the qr code to join contest for amber pillow, figurine and in game items.
Ctrl_Alt_Del
Read reviews, at higher level need to use "original resin" a energy that is recharge everyday or pay money to recharge. The only mulitplayer aspect is join other people to fight boss and clear dungeon. But other people can steal mining resource in your world, some respawn once a month.
Ctrl_Alt_Del
The game is not stable for my pc with intel igpu. Default settings was med 1080 p. First time could play for more than 2 hours. Then the image suddenly freeze but still can hear the character react to key press. After that even if change to lowest and 720p also freeze after 10+ mins or sometimes immediately after loading. :(
Found the problem. Windows 10 reported the game freeze was hardware failure, LiveKernelEvent Code:141. Searched online found is related to gpu. Someone posted in the game forum that the game may has a bug with intel igpu driver. When the gpu load while running the game reached above 80%, it will cause the gpu driver to crash, causing the game graphic to freeze.
Temp solution is run at 800x600 and low settings. :(
Android version graphic is also capped at 30 fps and lower graphic detail than pc version, although my phone sd 865 can handle it. Hearsay 60 fps and higher graphic detail for android version coming in v1.1 update.
CrapAss
It is an extremely important game that debuted.
It basically disrupted the Apple Arcade, due to its free-to-play strategy and has no reliance on pay-to-win for single player. Only competitive play (PVP) will see whales playing gacha often to get the correct team of characters. So the argument that games in Apple Arcade have no micro-transactions has no advantage anymore since consumers can simply ignore the subscription paywall and download Genshin Impact instead. And players can play it for a very long time.
So Apple will likely have to do a second round of project cancellations because of an exodus of existing subscribers from their service.
I am also very impressed with the development team from China. Based on the requirements in technology and aesthetics, they are likely to be mostly Masters/PhDs graduates with extensive experience, judging from their previous games, Honkai Impact 3.
So this action RPG genre is now under lockdown, because the barrier to do better than Genshin Impact, is just insurmountable (with the exception of Nintendo themselves).
Luckily, I never bothered with the Unity engine. Just because the Chinese team can use it to make Genshin Impact, does not mean you can do the same.
game is good for sure. but i didn't know only masters n phd can do this. as usual, sinkie mindset.
Trueblue82
If you have played Mihoyo's previous game, Honkai Impact, you will be less surprised, because the graphics is also very good, just that Honkai is more structured mission base.
also avail on pc/android/ios
even their 3D anime short is better than netflix's 3D anime series
