Gimbal for mi9t pro
teckgamer
Hi guys, looking for a recommendation for gimbal for mi9t Pro since it doesn't come with optical imahe stabilisation.
Considering the three options are:
Atom snoopa foldable
Feiyu vimble 2
Moza mini s
Any recommendations and thoughts? Looking at budget max $125
Would be using it to record overseas trip and some edits
yusoffb01
it already has 4k eis that you can even run with so gimbal is unnecessary
if you want a gimbal buy funsnap. it has removable batteries and was $60 in lazada
But as you can see the eis perform better than the gimbal, no bobbing up and down when walking
teckgamer
EIS is only for 30 fps?
teckgamer
Wah the wide camera stabilisation is out of the world. Unfortunately the main camera stabilisation is meh
Tony_Chua
zhiyun crane m2? can use phone, gopro, compact camera or mirrorless camera.
i'm using zhiyun crane m2.
duriansaber88
DJI OM3 or OM4 SE smartphone gimbal? Suggest to purchase during Shopee or Lazada 9.9 mega campaign, and the price of OM3 will be around $100 only
