Going for a ITX system (Jonsbo V3+)
wanrong
Hi would like to get a new ITX system(as budget as possible) as my 4yr+ PC is failing me every other day.
All is gathered from tradepac/PCtheme:
Mobo + CPU: MSI H81i + I3-4130/4340 or 15-4440(I3 bundle:$263/$309 and I5 bundle:$349)
RAM:G.skill value ram 4GB 1600 ddr3 X 2 : $98
Casing: Jonsbo V3+: $79
PSU:TT smart SE 530W 87% Modular : $70
HDD: 1TB : $70
GFX: Unknown
Total: I3-system: $580/$626 , I5-system:$666
This is my basic setup that i gather from the pricelist do i get better discount at PCtheme or Tradepac?
And any recommendations for value GFX that is better than 9600GT?
Thanks guys been some time since i do this really appreciate all the help :)
Jian19
i3-4130 + Asrock h81i ~ $246
Crucial 8gb ddr3 ~ $90
Wd blue 1tb ~ $78
PC 7750 ~ $85
Fsp hexa 500 ~ $58
Jonsbo v3 ~ $79
$636 buy and DIY @ tradepac ask for discount...
MoneyFace =p
HDD: 1TB : $70
GFX: Unknown
What's the purpose of PC?
MoneyFace =p
CPU+MB: Intel Pentium G3220 + MSI H81I @ $170
RAM: ADATA Premier DDR3-1600 CL11 8GB @ $85
GPU: PowerColor HD 7750 1GB @ $87
HDD: Western Digital Blue 1TB @ $76
CASE+PSU: Jonsbo V3+ [White] + FSP Hexa 500W [80 Plus] @ $125*
Get Tradepac to match the price from PC Themes.
Total: $543
Buy and Build from Tradepac, #05-19 after price-matching*.
wanrong
Hi, thanks for all the reply but forget to mention that this will be my main PC. I would like to play newer game when possible but theres no need to have MAX faps or on Ultra settings . :o
So i cant decide on Getting a I3 or I5 not looking at anything lower than that.( I dont mind older gens like sandy or ivy bridge)
I was looking at the ATI 7790 for mid range game support. (Needs to have card <190mm because of the casing)
Anyway i was quoted this:
jonsbo v3
Corsair CX430M PSU
MSI h81i
I5-4570
G.skill 4gb X 2
total ~590(490 for I3-4130)
not from simlim btw. Is this actually a good deal? Thanks and sorry for late reply :)
Jian19
Might wan to consider CM 120 or 130 for longer gpu..
Wd blue 1tb ~ $78
Leadtek gtx650 ti boost ~ $201
Superflower hx 500 ~ $89
CM 120 / 130 ~ $80/90
$781 buy and DIY @ tradepac ask for discount
wanrong
Wd blue 1tb ~ $78
Hi, sorry to keep troubling you. But isnt 7790 slightly better than a gtx650? For the size 7790 matches my requirement of <190mm however if i need it to be bigger i can opt for a Jonsbo V4 case as well.
May i know the reason for choosing superflower hx 500? Cause for the similiar price range i could get a Corsair cx430M modular or a thermaltake 500W 87% modular PSU.
Lastly would it makee alot of differences if i choose an I5 over an I3 ? Considering im using C2D E6600
Ark Law
Quieter psu and reliable brand
wanrong
Since i havnt seen the actual V3 or V4 yet, whats the current MATX board right now?
In the event of me picking a V4 case which has more playroom for size. :o
MoneyFace =p
CPU+MB: Intel Core i5-3350P + ASRock B75M-DGS @ $271
GPU: PowerColor HD 7790 1GB OC @ $162
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
CASE+PSU: In Win BK644 + Powerman IP-P300BN7-2 300W SFX [80 Plus] @ $89
Solid, and yet still compact chassis at roughly 12.5 litres that is similar in dimensions to Alienware X51.
Total: $704
Optional:
RAM: ADATA Premier DDR3-1600 CL11 4GB @ -$42
GPU: Leadtek GTX 650 Ti Boost 1GB @ +$39
Buy and Build from Tradepac, #05-19.
Jian19
The 650ti boost is similar to 7850...proper mid range card
No point get a i5 but use a 7790...gaming wise better gpu will give u better frame rates
i3 is still a very good proc for normal usage and gaming..unless u doing other stuff that require quad core then go ahead..but with ur budget I think i3 is better
The Superflower hx 500 is a 500w 80+ gold semi modular power supply , much better then those 2 others u wan, and perhaps cost $10-15 more only..
wanrong
Oh the hx500 i found is not a semi modular version, thanks alot guys made some conclusions now. Much more clearer into what i will be getting :o
MoneyFace =p
wow thats really small and compact :eek::eek:
If i were you, i would actually drop 4GB of RAM for a GTX 650 Ti Boost which still fits within the 300W PSU envelope but can be quite a tight fit and uncomfortable for some.
jtjt00
Jonsbo V series cooling is lacking compared to U series.
wanrong
drop 4gb? because it hinders with the gpu?
