not sure..
intermittent display, sometimes no signal
took a while to boot up..
too much to really test it
most likely will just tear apart and test individual part and keep as spare part
U shld do that 1st or whatever testing you can do and report here so that we can give comments. With nothing done and nothing reported, we also cant advise or give comments.
Test and swap cable, use 1 gpu, use different hdmi/dp ports, change to another monitor/tv, check power socket/avoid extension, etc, etc.
my apologies.
eventually decided to just strip the desktop and keep the hw for future use if they are working fine
gpu to test in future, mb and processor, don't know what to do with it yet, no spare hw to test it![]()
funny thing is with ram 32gb, gpu, it takes few minutes to reach windows 10 log in page![]()
my apologies.
If you got a spare hard disk or SSD, try installing a fresh copy of Windows and see?
Check system event logs lor. See got any failing issue etc.
How long is your hdd?
Try boot up using 1 ram and 1gpu, see if it is ok?
