GooGoo custom computers
ZhuTou!
Its ur own money so its up to u how to spend it
Not many people are willing to spend extra 500 juz bcoz they have no time
Even our high flyer people here also diy themselves
They are busy too
They buy the parts first and assemble when they have time
Diff people have diff mindset
ieast
So far I had bought 3 computer system from googoo. First I think their price is definately more expensive than diy or sls shop.
The reason for buying from them is convenience...deliver to your home..any technical issue also onsite. Their support is definately very good.
If you are looking for cheapest deal..then googoo is not for you.
If time and convenience is important then googoo is good.
Mycrus
not bragging... just commenting that googoo is not so bad or that overpriced like $4K like ddwmk2002's setup
Mythmaker
time + convenience + cheap + aftersales = fortran
No reason to go googoo or potterhouse nowadays...
recca143
if u really tat busy, juz approach fortran, or any other free bros around here who are willing to help... :o
Mycrus
Googoo delivered today... all boxes, all literature, all loose accessories were delivered as well.
i'm quite satisfied with their service!
Mycrus
i think you are right about going to fortran... my top card was doing 90+C while playing games... then after looking at the forums it was there that these kinds of non-reference cards have heat issues when in SLI.
alright, i must admit that i did ask googoo to get that specific card... but they should have done their homework and advised me that it is not a good idea...
the gigabyte gtx580 superoverclocked is a non-reference card... it has a fancy looking heatsink and fan setup that actually vents hot air into the case... when you stick two or more of them close together, the top card just sucks in all the hot air..
anyway - i've fixed my own problem by buying a truck load of noctua fans.. and doing some readjustments as to where the cards are placed.
my top card is idling in the 35-37c range and is at 80+c when in load... i'm modding a vga hood and will see if it further improves
i'll definitely give fortran a try when i upgrade this rig to water cooling...
ov2rey
haha... you must be joking..
ref GTX580 even hotter then 3rd party cooling..
please go do your research again
Roundup: a review of the super GeForce GTX 580s from Asus, EVGA, Gainward, Gigabyte, MSI and Zotac (page 1: Introduction) - BeHardware
i'm using same card as you. all GTX580 card are hot when you load even Palit GTX580 3GB full load can hit 99degree
MSI GTX580 or other brand when come to SLI is even hotter
Mycrus
can't post links but google "GTX 580 3-way SLI Overheat - Cannot Solve" it is on the overclock.net forum
try reading this thread, it shows that all aftermarket coolers have issues when in 3-way sli.
the suggestion is to use reference (blower type) cards for 3-way sli air cooling.
it is not advisable to have GPUs at 90C
mine are running in the high 70C to about 80C even when running 3D surround, but to achieve this i've had to improve cooling and space out the cards between the 1st and 4th pci-e lanes
5 x 120mm x noctua S12b fans (exhaust, 1 top mounted, 4 side mounted near the graphics card)
4 x 120mm x noctua p12 fans (for top mounted h100 push/pull setup)
1 x 120mm x noctua p12 fan (blowing air into the graphics cards, installed in the VGA hood after I mod the hood to fit)
1 x 140mm x noctua p14 fan (exhaust)
1 x 120mm x cooler master fan (5.25 drive mounted intake)
HAF932 case has existing 1 x 230mm x cooler master fan (lower front intake)
yes, that is a lot of fans - and no it is very quiet - because they are noctua fans / and i've lowered the rpms on the cooler master intake fans
i don't think anybody has succesfully run 3-way sli with this card on air cooling.
p2311967
Shouldnt you guys try to use water cooling for your system? Saw some one did that. Quite neat n temp low after project done. Also running 2x 580 if not wrong.
ov2rey
sorry dude one of my friend running Gigabtye GTX 580 SOC 3 way SLI
on this set up
2600k + Gigabyte p67a-UD7 with modded bios
G.skill ram 2133mhz 16 gb
WD black raid 0 1TB x2+ WD blue 640gb
Gigabyte GTX 580 SOC SLI 3-way
he able to play BF3/batman/ other game without any problem..
Mycrus
on this set up
G.skill ram 2133mhz 16 ghz
ov2rey -- i'm very interested to 3-way sli this card, please help to advise what temps your friend is getting with his setup! i've just tried to sandwich the 2 cards i have now and i was getting 98C on the top card.
ov2rey
your side panal do it have a hole for for gpu?
Mycrus
it's not an airflow problem... beside the GPUs there is 4 x 120mm noctua s12b fans as exhaust / in front of the GPUs there is a 1 x 120mm noctua p12 fan as intake
would appreciate if you can get the temp readings from your friend for the 3-way sli... as everything i've read so far says that i can't be done...
Mycrus
Googoo has helped me solve my GTX580 SOC problem to my satisfaction.
i'm getting my gigabyte GTX580 3gb 3-way sli in a few days!
Try to find a shop in sls that will help you this way...
So is Googoo worth it - hell yeah!!!
i'm doing another build in a 3 years or so and will still use Googoo if they can do watercooling for me...
junialum
Mycrus
You are paying close to double for simple customer service.
With that price you paid you could have gotten as many replacements on your own to your heart's content.
Also did u have to sell off your gigabyte cards yourself?
Your post: http://forums.hardwarezone.com.sg/g...80-super-overclock-gv-n580so-15i-3531136.html
But a man's cash is his to spend. Glad you're happy! And happiness is is most important :D
no not double, i did the sums and it is about $500+ more expensive.
apart from a very very few good ones, sls doesn't provide 'customer service'
localITguy
Suspended
Is the shop still in business? Is their assembly and testing still of good quality? I visited their website today and will be placing an order for a $900 desktop PC for general browsing and YouTube. I'm OK with the slight markup in component pricing compared to assembling myself.
Just worried that this thread is abandoned and they may have gone bad.
yep. they still in business. dun worry buy stuff @ GoGo before
LesterQ
Are you guys joking?
