[GPGT] Salmon fillet 150g, 3 for $2~!
reaverx
eat more die already ... TS dunno farmed Norwegian salmon tonnes of chemicals ?
wadtheEel
Sheng siong got good quality salmon at good prices too. Put butter, garlic and lemon juice then throw inside airfryer 20mins come out jin ho jiak
3sth3r
I think they refresh every night accordingly to what someone posted here. You should still be able to make the purchase.
On a side note better go claim your fillet fast. Not sure how long before they replenish
Sent from Google PIXEL 2 XL using GAGT
Okok, so I can buy 3 pieces after all?
Tomorrow I go down again.
3sth3r
This one is $0.66 per 100g. Very good price leh. Plus fillet and individually frozen. Just nice for one.
whatheheck
Test the system lo. Anyway no harm trying is only a dollar
Even if gets through Qoo10 system most probably they will refund when they see the hp no repeated? They say want to get to wider target audience so limit quantity. But can try lo if want :s13:
3sth3r
Anyone gotten refund yet? Or need attempt then will get refunded?
The listing is stupid leh, it says 3 qty per person. Then when you get E ticket and see more clearly, 2 per Hp number. Remaining will be cancel. So do I or do I not need to do anything since I have already gotten 2. Make the whole thing maciam scam. Tio catfish like that
Phoooey
Is that the best way to cook salmon?
Airfryer tend to "squeeze" out the oil from the food.
In this case, the omega oil from the salmon are the good eicosapentaenoic acid (EPA) and docosahexaenoic acid (DHA).
wadtheEel
Airfryer then to "squeeze" out the oil from the food.
In this case, the omega oil from the salmon are the good are eicosapentaenoic acid (EPA) and docosahexaenoic acid (DHA).
I usually jiak with the oil as the sauce. I wrap the fish in aluminium foil before putting into the air fryer btw
Phoooey
Oic, that makes sense.
Aluminium foil keeps the moisture in when used in oven-baking.
Any issues with cooking aluminium foil in a airfryer?
rbtr8r
if u google.. its not good to cook things in foil... the aluminum will leak into the food
not sure who invented that method... as no professional chefs will do that.
foxer77
if had 3 qty in your system it will not allow u to buy.. As when i try it display max qty purchase.
heroking
how can mine after i scan cannot see the voucher inside the app?
is it need to add the voucher into the app?
