GPU overclocking weird sound
kendallkoh
Im trying to overclock my GPU using MSI afterburner. Settings is max power while clockspeed +240.
While running 3Dmark demo, i hear this sound that resembles a soft screeching. It sounds like something small spinning at super high rpm. Im just a little worried. Any one might know where this sound is coming from? Should i lower my settings?
Sent from using GAGT
Phen8210
1. check is any plastic residue left in the card..
2. might be coil whine noise.
3. check fan speed in rpm? if too high definitely not ideal..
4. rma xD
royfrosty
High chance is coil whine. It is normal. But just irritating.
kendallkoh
4. rma xD
Yea it sounds like a whine noise thing.
When u say fans, is it the one i see on the card? Or is thr some other hidden fan. Cos the fans outside dont seem to be the cause.
Phen8210
rma lor.. hope your next card no noise haha..
last time had 2 powercolour 280x.. both also got noise.. jitao sian.
volume was quite distruptive
kendallkoh
what benchmark you run.. how come can 200 fps de -.-??
Im still running some other benchmarks now. Imma take a screenshot for u later.
Im currently running the series of 3Dmark demo benchmarks.
I think cos is the cui benchmarks la. Thats why so high. The firestrike benchmarks is a decent 50fps range.
Results: http://www.3dmark.com/3dm11/10611744
