GPU problem?
leehuaqing
Hi there,
Recently while using computer, my monitor would suddenly went blank at random timing.. It's will show "No signal detect from HDMI"
Did some troubleshooting,
1. Removed my GPU and plug my HDMI/VGA cable onto mobo slot and No problem for both.
2. Insert back my GPU and plug back HDMI onto GPU slot, no problem but after few mins the problem return.
Is it GPU going uplorry? If so, any recommendations for new GPU with budget of $200? (Mainly using my computer for HD video streaming, Nox player max settings on Lineage 2 that runs on Unreal Engine 4 and fb games nia)
gld998
Hi there,
its the hdmi port bah.. use dvi or mini hdmi port instead.. i kena b4 switch between 2 machines using 1 monitor
leehuaqing
Highly likely GPU gonna uplorry.
If no more warranty, at $200 range can consider Zotac GTX 1050 TI 4GB OC Edition (2 fans) for $190 at qoo10 sold by Firdouse Electronics after applying $50 cart coupon and $10 shop coupon.
OOS liao.. :(
Tried vga/dvi also same issue.
