Graphic card problem?
Xiao-Jie
Hi all,
I would like to enquire if that my graphic card is giving me the issue or is there any other possible reason. I have no issue with watching video on youtube or surfing the net. Thank you!
In-game During Dota 2
In-game During CS:GO
Maeda_Toshiie
Did this start after updating the drivers?
Plausible diagnosis: the GPU is about to uplorry.
Xiao-Jie
I am actually having low fps in game. So I went to remove the ram and stick it back. After which this happen. I saw there is a new update for the driver, so I updated it as well. But before the update this error already happen. I have no issue when I game in the afternoon only after I remove the rams then this actually happen.
Maeda_Toshiie
Hmm...
Reseat ram and do a ram test to rule out ram errors. I suggest memtest86.
In addition, reseat the graphic card just for certainty.
Xiao-Jie
Hmm...
My mobo only has one slot for graphic card but after reseating the ram now my games work! Thx for the help but I am wondering how can I actually improve the fps for my games?
Maeda_Toshiie
Good to hear that it works now.
I assume that you have low frame rates and want to increase? If that is so, the source of bottleneck needs to be found. Please post the following information:
GT9600. Kind of aged.
The probable bottlenecks are either the CPU or GPU. I think you should post your system config for better assessment:
1. CPU -
2. GPU - GT 9600
3. RAM -
4. Monitor resolution -
5. Games - Dota 2? CS GO?
Xiao-Jie
1. CPU -
2. GPU - GT 9600
3. RAM -
Thx to your help. I am able to play my games but I am having bad fps in dota 2 and sometimes it also crash for no reason. haha!
1. CPU - Q6600
2. GPU - GT 9600
3. RAM - 4gb but window xp 32bit only up to 3.25gb
4. Monitor resolution - 1024 x 786
5. Games - Dota 2? CS GO? for now thats about it.
Maeda_Toshiie
Google-fu turns this up.
Results: CPU Benchmarks : Dota 2 Performance, Benchmarked
Results: High Details, 1920x1080 : Dota 2 Performance, Benchmarked
I usually don't like using THG but I'll be lazy for now.
Good news: DOTA 2 is multithreaded, so that Q6600 is well used.
Bad news: Even so, that Q6600 is outdated. Of course, you can always overclock it; the Q6600 (esp. G0 revision) has a overclocking reputation.
Your GT 9600 is probably on par with a GT 630, which is at the bottom of the second chart. Of course, those frame rates are for high settings at 1080, a resolution far more stressful than your current settings.
I'm assuming that your connection is not the cause of slowdowns.
Then again, it might be a game issue:
Dota 2 framerate drops.
Given a C2D/C2Q based system, you have two options:
1. Get 2nd hand CPU and GPU off the bazaar. Of course, a more powerful GPU will probably consume more power, which your PSU must be able to handle.
2. Replace the entire system.
Xiao-Jie
Wow! Thx for all the information. Appreciate it!
But wouldn't it be too costly to change my whole system for just 2 games which are not really that graphic intensive?
I am certainly sure my PSU will be able to support. Mine is 620W.
Are there any other ways which I can improve my system at a lower cost? :s22:
Initially I was tinking to get an additional 4gb rams, change to windows 7 64 bit, get a 7770 and an additional SSD 128gb.
Maeda_Toshiie
Hmm, there are very few 620W PSUs out there. Is that a Seasonic, Antec, or Corsair? Those are fine. I sure hope that it is not this!
ACE 620W PSU with 12cm Fan and SATA 24-Pin Model - Grey: Amazon.co.uk: Computers & Accessories
That SSD will certainly increase loading speeds (when the program is installed on it). Probably the most visible upgrade.
Yes, the 7770 will be a significant upgrade.
I don't think the extra 4GB will make a significant difference. However, don't stop yourself if the ram price isn't high. DDR2 or DDR3?
Hmm, just curious, what is your mobo model?
shawntyq
i used q6600 before. u can easily oc to 3.2ghz.
perhaps that alone could help u pretty much.
for gt 9600 u can oc 50mhz each time after a 3dmark test and try researching abit more to see whats the potential OC speed u can get from the GFX card.
Maeda_Toshiie
Overclocking the Q6600 was an earlier suggestion. That is up to TS to decide. Alternative is to get a 2nd hand Q9550.
Xiao-Jie
Hmmm. I think i will do the upgrade instead. Any recommendation for mobo+Cpu?
I will be keeping my psu, hhd, dvd. Best if can stick to a budget of 600 to 700 together with a 7770 and hopefully if able to squeeze in a plextor m5p 128gb as well.
